Question about Kenwood KAC-8104D Car Audio Amplifier
Blown something found the problem just need to solve it !
I have blown a 6 black things around the edge of the amp a KAC-8104D if anyone has the service manual or what those black things are with the heat paste under them let me knoe
  • sxc_5_star_p Apr 23, 2009
    thanks for your help the reason i need the service manual is they have been burnt out i checked the rest of the board and it only seems that the fets have blown
    Scholar:
  • 34 Answers
Those black things are likely the MOSFET transistors (the bits that provide the amplification). They likely look similar to these.
Your problem may be deeper than just these units being blown - especially since there are 6 that are gone. Have you been overdriving the amp? Using speakers with the wrong impedence?
Anyway, you can try www.user-manuals.com to see if they have the service manual. You could also try to source new mosfets from online retailers (eg digikey, www.sayal.com) - just read the numbers printed on them. You may also want to try to determine why they blew in the first place. I have fixed amps where one or two have gone bad because of being overdriven, but 6 makes me think that something else is wrong. Unless the am has a number of MOSFETs serving each channel. Eg, 3 MOSFETS per channel on a 2 channel amp..
Posted on Apr 22, 2009
The amp.
check power fuse make sure it's not blown and gettin proper 12 volts if all connections are properly fixed maybe get it checked out
Jun 06, 2010 | Kenwood KAC-8104D Car Audio Amplifier
KAC-8104D Car Audio Amplifier: Fuse keeps blowing why...
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
May 16, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Amp is not operating at full potential also red portectant lite comes on kenwood kac-8104d
make sure all your wires you are using to connect the amp are 4 gauge check your ground make sure its drilled threw thick metal scuff off the paint that its grounded too and check how you have your subs wired see what ohm there wired in the you can get more power out the amp in 2 ohm then 4 ohm
Mar 31, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
The Red & Black wires connected to my AMP touched
You blew the inline fuse on the AMP power wire. If it was not fused "inline" you may have blown a fuse internal to the amp. Look on the amp(or consult the manual) for the location of fuses "internal" to the amp.
May 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
I turn on the amp then the fuse blows??
If the fuse only blows after the remote voltage is applied, the amplifier probably has shorted output transistors.
Dec 01, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
198 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
