SOURCE: Replacing alternator in a 2001 Dodge Intrepid
the easiest way is going to first be to remove the serpentine belt which requires you to loosen the nut on the end of the idler pulley just above the alternator, then behind the pulley is a bolt with a 13mm head on it that you will want to loosen after the pulley is loose to relieve tension off the belt. Remove the belt. Next make sure you remove the battery cables to ensure you dont fry yourself to the car when unhooking the electrical connections from the alternator, your battery is located on the passenger side, down behind and underneath the headlight. Then go under the car and remove the black plastic clips that hold the splash shield up under the bumper. After this the alternator becomes as accesible as it can be, remove it from the bottom. Thanks for using fixya!!
SOURCE: Need Diagram of water pump on a 1998 Dodge Intrepid 2.7,
the water pump is timing chain driven and to replace it requires serious disassembly of the engine. it is a 13 + hour job and is not for the casual mechanic
SOURCE: disable alarm 1999 dodge intrepid
HOW DO I MANUALLY DISABLE THE ALARM FOR A 99 DODGE INTREPID
