Question about Panasonic CQ-C5301U CD Player
Rear wiring connection/wiring
Need to find the rear wiring connections and where they go or hook up to
    Novelist:
  • 149 Answers
Red= (switched)power+ black is ground = connect to metal surface yellow is memory needs battery+ at all times white/whiteblack is front left speaker grey/greyblack is right front speaker green/green black is left rear speaker violet/violetblack is rear right speaker
Posted on May 29, 2009
Hook up radio to jeep cherokee
buy a 12 volt lamp tester (like a screw driver)check the wires when car ignition switch is turned on ,connect the wire side of tester to metal ground of ur car which supposed to be negative and other side of tested pin to the wires jack of ur car which is for radio connection previously,find out 2 connection points which are positive terminals one lights when igni switch is turned on the other one is permanent power terminal.now there are three wires of ur new radio one is black which should be connected to ground or metal body of ur car negative terminla and yellow connected to permanet power terminal and red one should be connected to power turned on with the swith which is called switched power
.now try to find out other four groups of terminal two for front speaker two for rear speaker each speaker has two wires ,can find out the connections by connecting a dry battery cell to the wires to identify which wires of speakers sound when battery is connected ,front pair of wires is for front left grey pair is for right front green pair of wires of ur new stereo is for left rear speaker and purple or blue pair is for right rear speaker
.these colors are globally known .the wires of speakers must not mixed with each other
black is for ground negative red is witched power and yellow for permanent power.
donot use long screws to fit ur new radio .Best of luck
Nov 18, 2013 | JVC KD-S5050 CD Player
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
When I hook up the rear speakers to my in-wall speakers, I can't get any sound. I have speaker button 1 and 2 selected.
Hi:
you need to clear that you connect wall speakers for font,center or rear (surround) speakers?
Seem you connect for Front speaker.
Rear (surround) speaker will have "rear" mark on the back of your reveiver.
In general you need to select both buttons 1 & 2 then check your speaker wires connect into "output1" or "output 2" hint: each output will have 1 for left and 1 for right speaker. Each Left or right speaker will have 2 connection 1 red color (+) and 1 white color (-). Try to match these colors code for your speakers connection.
Feb 25, 2011 | JVC RX-884V Receiver
I have an old Chevy and I'm trying to hook up my Kenwood kdc-138 stereo. I have the red wire connect to the red ignition wire and black wire to ground. I have the yellow wire hokoed up to the ignition...
The fact that your speakers have only one wire, indicates that they are the old negative ground type. You will have to buy new speakers, or try and connect the negative wires of your speaker wires from the radio to the car body (chassis) and try that. Normally you will get a bit of static when you start your engine
May 31, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Jan 13, 2009 | XO Vision XOD1735 Car DVD Player
Troubleshooting amp setup
You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
Jan 05, 2009 | Car Audio & Video
Best method for connecting rear speakers yourself
The other wires in the back by the speakers are NOT speaker wires. It is possible to cause a short circuit in your car and or damage your unit by hooking up the wires from stereo to non speaker wires. Smoke from the dash is never a good sign. Hopefully nothing is shorted. These are the correct wire diagrams for your car. Hook them up just as described and you will have sound in no time:) If there is no sound check all fuses. Hope this helps.......Let me know what happens.......GOOD LUCK
Left rear (+) is Brown wire. Connect that with the Green wire.
Left rear (--) is Yellow wire. Connect that with the Green/Black wire
Right rear (+) is Dark Blue wire. Connect that with the Purple wire
Right rear (--) is Light Blue wire. Connect that with the Purple/Black wire.
May 30, 2008 | Pioneer AVIC-N2 Car DVD Player
Panasonic CQ-C5301U CD Player Logo
188 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
