Question about RCA TruFlat 27F520T 27" TV
Rca truflat ok when I turn on the tv the note book is on and wont go away until I press the menu button. the it will start doing a channel search by itself and then it will turn off and then on again.And yes the turn on and off timer is on off. Help!!!1
Press the note book button twice we'll once will showing .
Posted on Oct 02, 2007
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
Emerson model #lc200em8g wont program with rca model remote rcu600m
Hello
Codes for Emerson TV with RCA- RCU 600 are
..........004, 006, 012, 023
..........024, 025, 026, 027, 028, 029
..........030, 031, 032, 033, 034, 035
..........036, 037, 038, 039, 041, 042
..........043, 044, 046, 047, 123, 124
162, 171, 177, 179, 191, 196, 208
1. Manually turn on the TV.
Find the three digit code for your TV in
the code list below.
2. Press and hold the CODE SEARCH
button until the INDICATOR LIGHT
lights, then release the CODE SEARCH
button.
3. Press and release the TV button (The
INDICATOR LIGHT will blink then
remain lit).
4. Enter the code using the Number
Buttons.
After your code is entered, the
INDICATOR LIGHT will turn off. If the
code is not valid, the INDICATOR
LIGHT will blink. Check the code list
and repeat process.
5. Aim the remote at your TV and press
the ON•OFF button. Your TV should
turn off.
Note: If your TV does not respond, try all the
codes for your brand. If the codes do not
work, or your brand is not listed, try the Code
Search method on page 16.
6. With your TV on, press CH+ (CHANNEL
UP) If the TV responds, no further
programming is required.
OK
Mar 22, 2011 | RCA 257003 Remote Control
I need a remote control
Hello
Buy one PHILIPS CL 034 Universal Remote Control. RCA is listed it its codes.
Codes are:
0704 0002 0406 0007 0011
................. 0611 0811 0312 0514 0720
................. 0102 0502 0601 0817 0917
................. 0835 0901 0103 0803 0211
................. 0912 0114 0519 0320 0420
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Switch OFF and switch ON your TV WITH ITS FRONT PANEL POWER CONTROL SWITCH EACH TIME BEFORE TRYING AN OTHER CODE.
OK.
Feb 25, 2011 | RCA TruFlat 27F520T 27" TV
Will any universal remote work on my rca f35673mb tv?
Hello
Jusy buy one Philips Universla Remote control. RCA is listed in its codes list. The model number is [PHILIPS CL 034]. Codes and proceedings are given.
Direct Code Entry
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
Jan 04, 2011 | RCA F35673MB 35" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Rca remote code for a trutech tv
Try this as all remotes work similar.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 26, 2009 | RCA 3-Device Universal Remote with...
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Tv problems rca 27f520t
i think a univeral control might help.
Aug 18, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
