Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung DLP HL-R5667W
The tv is 2 years old. The tv started out with color discolloration once in a while. If we tapped on the side of the tv the color straightened out for awhile. The is no loud sounds coming form the set. Now the tv has smeared colors on half the screen all with all colors distorted. It will still stop if you tap on the side of tv. tonight the tv freezes up the sound goes off and the tv shuts off by itself. HELP!!!!!!!!!!!!
    Genius:
  • 1,030 Answers
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. [email protected]
Posted on Dec 10, 2007
SOURCE:
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
Samsung DLP HL-R5667W, seeing little boxes of static flashing
samsung color weel replacments are all the new air bearing type insted of fluid type. if you replace the new color weel , color will look bad. also note when ordering your replacment make shure it comes from samsung and not just a generic model.
the original replacement will come with a set of instroction to reset the dmv ajustments.
find the dmd pcb and look for a2 jumper that is visable through a small squaire remove the jumper. then folow instrustions with new color weel.
hope this helps.
regards,
daniel.
Jan 13, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Feb 05, 2008 | Televison & Video
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
