Hello! The required voltage is 24 volts...which means two 12 volt batteries connected in series...It sounds as if you have two 12 volt batteries connected in parallel...Which doubles the amps and leaves the voltage at 12 volts...Connect the negative of one battery to the positive of the second battery...Then from the positive of battery #1 to the negative of battery #2 is the required 24 volts for the Kole...Guru...saailer
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
You usually don't need a capacitor because your car can keep up with the power requirements, especially since your system isnt too big (no offense). But if you wanted to get one, i would only get a 1/2 or 1 farad cap.
First off Charging the capacitor can put you holding a high power voltage source. This can be very dangerous. It is enough to kill you. I suggest for safety go ahead and mount the capacitor in its location. The easy way to charge a capacitor is using a 12 volt Battery Charger. Hook the charger up to the capacitor just like it is a battery. + to + and - to - ... Charge the capacitor until the charger meter falls to near zero amps or indictates full charge. No need to use a light bulb or anything. The Charger comes with it own limiting circuitry. I will be posting the wiring instruction shortly.
