Question about Mitsubishi M-VR700
No sound sound system 2.1 sony sa-w10
  • 1 more comment
  • ponny Sep 23, 2007
    I have conected sound system (sony sa-w10)
    but ther is no sound
  • ponny Sep 25, 2007
    ok. I conect speakers to (front speakers) left and right. and subwoofer to (subwoofer uot)and there is no sound.
    cant I conect speakers to surround in back of
    amplifier, just to try?
    thank you
    (djproaudio)
    no I don't have manual do you know where I can get it,? I search the web but no luck.
    any idea.
    thank you
    Dj proaudio
Hi, I've had this problem with the M-VR400 and apparently I had the Tape2 Monitor button pushed on, and I was trying to listen to Video-1. Well, mentally I said I have nothing connected to Tape2 Monitor so I figured the machine couldn't decide on sound Input properly, so I turned off that button and my Surround Sound came back on just like Magic! :) Hope that helps.
Posted on Nov 25, 2007
  • 515 Answers
You really need to be a little bit more specific. Do you have everything connected properly, according to the manufacturer's requirements? In our database, I show the Sony SA-W10 listed as a Subwoofer. Are you located outside the U.S.?
Posted on Sep 23, 2007
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Sep 25, 2007
    Do you have output going to your headphones? Also, try without the sub. Make sure your have the proper speaker output sets. Some models have option for multiple speakers, and this setting needs to be correct. You can connect the surround to the back of the amplifier, it should work. You need to determine where the problem lies, so testing every possible configuration is your best option. Do you have the manual for this unit?
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
I have a sony sub model sa-wm20 will it work with this mini system
Read the manual.
http://www.retrevo.com/support/Sony-SA-WM20-Subwoofers-manual/id/752ag408/t/2/
You would use the Speaker Terminal hookup option. Your front speakers would attach to the sub's speaker terminals.
May 02, 2011 | Sony MHC-881 Shelf System
CANT CONNECT TO INTERNET? ON MY SONY VAIO PCV-W10
sounds like a virus has destroyed the ethernet controler i would reinstall windows to solve this hope this helps
May 23, 2010 | Sony VAIO PCV-W10 PC Desktop
Sony SA-VA10 Shelf System Powered Monitor Speakers. Constant Buzz .. around 1K . .sounds like power supply. Not attenuated by increase in amp volume. Help
Secondly sounds like the power supply filter capacitor has gone bad. Write down the value off the label and purchase one at your local electronics parts place. It will only be two solder leads to unsolder and solder back. But first check the other place for that symptom, an open ground near the input jack going into the amplifier, or broken input wire/plug.
May 19, 2010 | Sony SA-VA10 Shelf System
I need the System Control Cable for my Sony SA-VA100 Speakers!
Need the System Control Cable to a Sony Sa-VA100
Jun 22, 2009 | Sony SA-VA100 System
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
Sony SA-VA10
Hi, Have you been able to locate the cable for your Sony speaker system? Thats a shame that they would take just the cable. Anyways, I have the sa-va10 model just like you. I just upgraded to a new sound system. And I have the cable. Tho, I m sure somewhere on the net, like ebay, amazon or even Sony should be able to help you. I would call them. Those speakers are not that old, and maybe Sony still has a ton of those cables in stock. Esp. since the system is only around 14 years old. Relatively thats still pretty new.
Jan 02, 2009 | Sony SA-VA10 System
Pcv-w10
you can make a recovery cd with your computer..does it run at all?
Mar 23, 2008 | Sony VAIO PCV-W10 PC Desktop
Help with Sony SA-VA100, No Sound!!!
Your best bet is to actaully purchase a better CD player, which sucks because it sounds like the one that Sony sent you in the VIAO system is defective. I would contact the merchant that you purchased the system from and demand them to replace the defective drive.
I hope this helps.
Michael Lazar
http://www.audioholicblog.com
Feb 26, 2008 | Sony SA-VA100 System
Mitsubishi M-VR700 Logo
239 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
