TV not tuning
I have a 21'' onida CRT tv flat . It works fine when i connect to DVD and camera in AV2 mode but in TV mode it is not tuning. I called upon a tv repairer who said tuner has to be replaced and so i got it replaced with original one but no help. Problem still exists. Now repairer says the TV is in hang mode since we had not used the Tv for three months.What may be the real problem.I checked the old TV tuner and it is working fine with other onida TV of similar model. Please help
  • 3,866 Answers
This guy is raking in the change on you. The tuner is for over the air signals, now you have a 3 prong connector RED,WHT,BLACK make there connected you can find the AUX,VID-IN by scrolling throught the channels on your TV hope this helps.
Posted on Apr 22, 2009
  • 700 Answers
Resolder the Vertical IC, it might help, or reflux it with a new lead solder. We experienced that. Somehow the vertical IC have some connection on AFC tuning.
Hope it helps.
Onida ky surround not funtioning av2
Main IC fault. Replace it. Av selection section inside it is not working. Damaged. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Televison & Video
My onida 21" black color
Possible there is a fault in soldering. Poor joints in the CRT base circuit of the CRT tube will result in poor connection after some use due to the fact the heating and cooling will detach off the leads. So use a good soldering iron to touch up all the points in your main board and the CRT board and it must work provided your tube is not faulty.
Feb 07, 2011 | Televison & Video
Due to high voltage my Onida Television got
the power supply filter condensor got leaky in ur tv,,,,,
well it will cost 80 rs... the picture will wave ,, call a tech person to change it. value of condensor 150mfd 450v
Mar 23, 2010 | Televison & Video
Lock code for Onida Black Dlx channel tunner menu
My Tv is locked and cannot start. it asks for password.
how to open it?
Apr 14, 2009 | Televison & Video
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connecting security camera
you can put at av1 or av2 or any video input jack. automatically camera works , and select the tv input contols very easyly..
Aug 30, 2007 | Orion1934 19" TV
21 pin input black and white
call a repair man that circuit is control by either by a chip or a transistor those components along with the othjer parts needs to be checked and replace.good luck.
Nov 28, 2006 | Toshiba 32DF46 32" TV
Televison & Video Logo
250 people viewed this question
Top Televison & Video Experts
Electro Med Services...
