Question about Cell Phones
My sidekick LX wont find service and says I can only make emergency calls. Also, after turning my phone off then back on all of my contacts were gone. My myfaves and everything. What can I do to fix it? I need my phone for work and for school so I need it fixed ASAP! Thanks!
  • 371 Answers
Your Sim card has failed, which is why your phone can't find your service provider, though you should, and your myfaves may be gone if the data from the sim card and the phones memory cannot be recovered.
There is nothing you can do to rectify your situation, so get into inmmediate personal contact with your provider first by another phone and then arrange for a personal visit to one of their offices so that you can salvage what you can as soon as you can.
There's nothing I can help you with, since it's a financial and phone provider issue.
Posted on Apr 22, 2009
I just got an unlocked sidekick lx 2009 and put in my att sim card. I can make calls but it is not reading my contacts. what do i do?
More than likely your contacts are still located in the old phone. Replace the Sim card back into the old phone and copy the contacts onto the Sim card, place back in your Sidekick and you then can locate your contacts.
Mar 11, 2011 | T-Mobile Sidekick ID Cellular Phone
My sidekick wont get service
Maybe it's because you're phone might off turned off and you didn't know. Because, if a sidekick turns off, normally when it comes back on everything is gone.
Oct 03, 2009 | T-Mobile Sidekick II
I forgot my 3# code for my sidekick lx
this is for the lx
put ur fone on the lock screen and press teh call button twice and u should see three emergency call numbers here u push menue shift and q and accept the defalt changes and this should let u in free and clear
this is for the sidekick 3 press menue and home button on the left hand side u should see three emergency call numbers here u push menue shift and q and accept the defalt changes and this should let u in free and clear
Mar 29, 2009 | Sharp Sidekick LX Smartphone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Malfunction!
sounds like your simcard isn't making good contact. try removing it and cleaning contacts. if that doesn't work go to menu-settings-network options (near bottom) and make surre it is on your service provider. if not select scan manually and when it pulls the list up select your provider and it should work. this also works with the att simcard in a sidekick lx after you change your sim pin number in sim center.
Sep 16, 2008 | T-Mobile Sidekick
Sidekick lx
while your on the privacy lock you press the call button 2 times, then the emergency call shows up , once that shows up yu press the menu button (the top left button w. tha 3 lines) while holding shift & Q .
& a message pops up saying if you want to reset to factory settings n yu juss press reset & it takes outt tha code n all tha things in the sidekick ..
your welcome :]
May 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
The sidekick Lx
You can try this. It works on Sidekick 3's
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
If that doesn't work you can trya Master Reset
1. Remove the battery and the SIM card from the device.
2. Flip the sidekick open; press and hold the letter 'r' on the keypad.
3. While holding the letter 'r', place the battery back in the device. DO NOT INSERT THE SIM CARD YET.
4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, re-insert the SIM card and battery and power up the device.
6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factoy settings.
Thanks to Sidekickskins.net
Feb 03, 2008 | T-Mobile Sidekick
Cell Phones Logo
496 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
