Question about Dryers
Lawn Tractor Not Doing Anything When I Attempt To Start It
My craftsman 1000 lawn tractor started running poorly then I started having problems starting it. I replaced the battery and it worked for a little while then it stopped working again. I replaced the switch and it started working a little while and stopped again. I purchased a starter and replaced the old and it still didn't start in fact it didn't do anything, I noticed a burnt fuse, replaced that and it attempted to start but didn't, then eventually it was back to not doing anything when I attempt to start it? I appreciate your help...
  • 1 more comment
  • corwinkr Apr 22, 2009
    No sir the fuse did not blow again, but I attempted to jump a cable from + side battery to starter, and when I attempted to connect other end to starter, I turned the key to the on position and it attempted to start, it kept going on and on but never started. I then touch the starter connection with the other end of the cable and still didn't turn over. I removed the cable from beneath the seat and attempted to start mower and nothing happened when I turned the switch. When I put the cable back under the seat it attempted to start when I turned the key...It seems that only when I have the jumper cable end connected under the seat on the positive battery post with it not connected anywhere else that it attempts to start, but never catches.
  • corwinkr Apr 23, 2009
    This morning I removed the gas tank cleaned the fuel filter, I am changing the oil and filter, I will be replacing the spark plug and I will spray carburator cleaner into the carburator to resolve that after I have done all of these things I will respond and let you know what is happening! Thank you
  • Samuel Charles Spriggs May 11, 2010
    Did the fuse blow again?
    Have you checked all the battery cable connections? -- sometimes what looks like minor corrosion at a connection will prevent enough current from flowing that it will produce the symptoms you describe.
    President:
  • 1,489 Answers
Let's try this. It sounds like you can get it to crank but it won't start. There is probably a fuel shutoff solenoid which is open only when someone is sitting in the seat. There is a switch under the seat so if the rider falls off the mower, the gas to the engine is shut off and the mower stops.
You can depress this switch by hand, or with tape, or whatever so you can start the engine without sitting in the seat.
Also, it sounds like you are clamping a jumper cable to the battery post and that allows the engine to crank. If I understand this correctly, it sounds lilke the connector on the battery post for the mower battery cable is loose, and when you clamp it, the battery cable connector is tightened and makes a good connection.
Sounds like two issues: fuel solenoid switch not closed when you're trying to start it; and a loose battery cable connector on the + battery post.
I think we're making progress -- let's keep working it.
Charlie
Posted on Apr 22, 2009
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
My craftsman lawn tractor will start but not move. Canyou please help!
mycraftsman lawn tractor model no. 917.273140 motor will start and run will not move
Nov 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dryers Logo
75 people viewed this question
Top Dryers Experts
