Question about HP Office Equipment & Supplies
Blank printin on the right middle ohe paper
We are hplaser1020plus while i amtaking printing there is blank printing on the right side of the middle paper about 1cm is not printing kindly let me know
  • 55 Answers
Toner may be low. Check the Toner level. You may have to clean the printer too if you have a new toner cartrage installed. You might also have a bad printer where its not able to fuse the toner in that area any more.
Posted on Apr 22, 2009
Blank printing
The posibility is you are using wrong paper or the right paper wrongly. Make sure you are using a thermal paper and it is facing up because it only prints on one side
Mar 28, 2014 | Sharp XE-A207 Electronic Cash Register
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
What is on the screen- is not what is printed. My entire 2-sided brochure is not printed.
ok but did you set up the 2 sided printin on your printer. check the control panel of your printer click that icon that your printer puts in your tray and check printing or paper make sure it is set to 2 sided printing there
Sep 24, 2010 | Microsoft Office Publisher 2007 for PC
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Epson stlus C88+ printer: paper pulled to one side during printin
Hi
Chances are the sensor for grabbing the paper on the left hand side is defective. Try to check if there are obstructions as well
Hope this helps
May 13, 2009 | Epson Stylus C88 InkJet Photo Printer
The photo tray
Go to printer then right click and select printer preferences. Under the tab features make sure beside paper source it says select automatically
Oct 30, 2008 | HP Photosmart C6280 Printer
Fax machine does not print on the right side of paper
Probably the thermal head is bad. It's a spring loaded bar inside of the fax machine. You might be able to shim it closer to the paper on the bad side.
Oct 20, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
67 people viewed this question
Seeker5211
Seeker5211
