Question about Alps MD 1000 Thermal Printer
ALPS Printer MD1000 Driver
I wish to use a Parallel Port printer (ALPS MD1000) with a laptop with only USB ports. Have purchased a BAFO BF1284 cable to do this with, somes with software. Drivers used have been detected by XP 'New Hardware Detected' and installed automatically. CAble software installed as per the manual and setup is as per the manual. The printer however will not work. Printer is in 'ready' state. Is there an updated print driv er for XPhome forthe MD1000 to make this work. I have tried Google and some discussion lists with no success.
    Sniper:
  • 58 Answers
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Posted on Sep 04, 2008
I HAVE THE SAME CASE.
Posted on Sep 03, 2008
The Printer in question use a sort of redirected port (MD-LPT1) and the driver bind to the fisical LPT1: PORT.
The USB cable driver probably create new virtual ports. And the default driver install cant bind to this virtual ports.
I think you can find a compatibl cable / driver on eBay. Just do a search MD-1000 cable or similar.
Marco.
Posted on Dec 22, 2007
I think that this printer operates using the parallel port in bi-directional mode. The standard parallel port printer cables are only one way - to the printer. That is my understanding from research I have done (limited, so I may be wrong).
Posted on Dec 13, 2007
SOURCE:
I was using TVSE Nova 130 printer on my pc parallel port with win xp pro os and it was working properly. Now I want to connect the printer to my laptop which has only a usb port. So I purchased a bafo...
go to device and printer. Locate your printer . right click the printer and select printer properties. click the port tab then change the printer port from LPT to usb port.
Jan 22, 2014 | Computers & Internet
Alps MD 5000
1. delete any MD5000 printer entries. *(I had no other printer entries defined)*
2. Use ADD/REMOVE programs to remove the driver.
3. Disconnect printer USB cable (one you bought on EBAY) My laptop has no Parallel port.
4. Reinstall Driver (I am using 2.2.4) specifying not to make it the default printer. For me the 2.2.4 install worked fine.
5. use the add a printer function to manually add the MD5000P. I pointed the install wizard to the 2.2.4 file created by the installation of the driver when it asked if I had a disk. for my computer that was:
C:\Documents and Settings\AMD64\My Documents\My Received Files\MDP224XP
5. after the printer definition was successful , I followed the steps from a
previous message in the ALPS group listed below listed below:
RIGHT CLICK MD5000P ICON, and open properties menu for said printer (this is the one you created manually)
click PORT TAB:
pick a USB port ( virtual printer port) from list *(the install set it to a
port of MD_LPT1 I selected USB001)*
DISABLE bi-directional support RADIO BUTTON,
click ADVANCED TAB:
click PRINT DIRECTLY TO PRINTER radio button,
OPEN PRINT PROCESSOR BUTTON on bottom of page,
from menu select ALMD224S (for print processor)
and DATA TYPE select RAW(FF AUTO).
I plugged the printer in a USB slot and printed test page and a color
photograph.
After this all worked I reset the USB port definition to reselect the bi-directional function. So I do run with the bi-directional mode
Note that Win XP itself will auto create a printer definition using a Microsoft driver "Alps MD-5000P (MS)" if you use this printer to print you will not get any of the ALPS functions.
But this seems to have worked for me.
I hope this helps you. I have only worked with an Alps MD5000 so I have not done this with any other model but the steps I think the steps could still apply because of windows requirements. I have not tried to install the driver on Vista so I do not know if it will work but it might.
Hope this helps.
If any of this is a problem you can contact me and hopefully we can work it out on the phone or chat or whatever
Good Luck
Jan 27, 2008 | Alps MD 5000 Thermal Printer
MD 1000 Thermal Printer: I need a driver for ALPS MD1000 printer that will ...
Go to the ALPS Yahoo Group. They have an extensive file section with drivers. Windows will use the default plug and play driver for the printer. The MS version is very limited. You should rename the MS driver to something else like "MS Alps Driver" and then install the ALPS driver you find at the Yahoo Group. These will give you full functionality.
good luck
May 16, 2010 | Alps MD 1000 Thermal Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Acer scanprisa 640p paralel to usb port problem
Push the parallel end of the cable adapter onto the parallel port of the printer. ... Ensure that the clips for the parallel port and cable are in the locked positions. 3. Unplug the USB end of the cable from the USB port on the computer, and then reinsert it.
Also look here-
https://yourbusiness.azcentral.com/use-parallel-scanner-usb-7712.html
Jan 06, 2018 | Acer ScanPrisa 640P Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
HP2100 PRINTER NEEDS USB PORT ON WIN XP LAPTOP.
You have to purchase a Parallel to USB printer cable.
Jan 03, 2009 | HP LaserJet 2100 Printer
Bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at [email protected] if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Alps MD 1000 Thermal Printer Logo
4,237 people viewed this question
Top Alps Office Equipment & Supplies Experts
Clive
Clive
defcon000001
Level 1 Expert
Jesse Walters
Jesse Walters
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
