Question about Lincoln Welding Tools
Welder will not start. The reset button usually will pop out by its self after attempting to start it several times. This time it stays pushed in and will not start. It seems to not be getting enough fuel. The little pump that runs off of the reset button appears to have a loose terminal. I am thinking maybe the little pump or the reset button box that all the wires tie in. If you have any suggestions I would greatly appreciate the help. Thanks, Richard Email> troismays@yahoo.com 903-802-3667
    Problem Solver:
  • 10 Answers
You need to check the reset button and if it is a small red cylinder shape and says tattle tale on it you will have to actually hold in the button while starting and continue to hold it for a few seconds after it is running with the choke completely off. thats just a common problem ppl have other than that if the motor turns over and never fires then i would have to say that u are on the right track
hope that helps some but without knowing what brand of welder it is and how old i cant really give an answer that i would be comfortable giving out because i would be guessing
Posted on May 22, 2009
Car won't stay started
check air filter to see if it is clogged. if it isn't check your fuel filters. you have one on the fire wall and one underneath the car on the driver side connecting the engine to the gas tank. open your truck, uncover the inside right fender panel, push the button on the switch and release the button. the button should pop out. the button has wires going to it. it is attached to the well wall under the cover you removed. try to start your car several timestil it will not even try to start. this release the gas pressure in your gas line. now you can replace both filters. after you replaced both gas filters, push the button in to reset it. try to start your engine, pump the gas pettle several times while you are cranking the engine. this will put gas pressure back in your gas line and into your engine. the gas filters should be changed according to manufacture time requirements. call ford parts department and ask how often the gas filters should be changed. any other information can be obtained at any auto parts company. try this first and hope it's not your fuel pump. your fuel pump is inside the gas tank. my fuel pump part caused $300. i recommend you buy it from ford. you don't want any gas leaks and ford will match it up if you need it.
Dec 27, 2013 | 1999 Ford Taurus
How do you set a popart pop-693ad watch
Ok, it took awhile to remember, but to reset the analog time or the day or anything else, first push the "mode" button which is at the 8:00 position on the side of the watch, 3 times. The first push will bring up the stopwatch, the 2nd push will change the alarm time, the 3rd push will highlight the seconds which on the watch face is at the 6:00 position. Release after the 3rd push and push the "reset" button which is located at the 4:00 position. It will start flashing the hour first. If that is what you need to change, then push the "start" button which is at the 2:00 position. Either keep pushing the start button to set the hour or hold the button in if you have more than a couple of hours to change. When that is done, if you need to change the minutes, push the "reset" button again and the minutes should be highlighted and do the same thing with the "start" button until you have the minutes set where you want. When you are done changing whichever thing needs to be set, including the alarm time, push the "mode" button and everything will stay set. This is for the Pop Art 693 AD watch which if you buy through ebay, it's an awesome watch with dual analog/digital time displays, etc. it comes with no instructions. If all else fails, go to the jewelry counter at a Walmart and hopefully the worker there can help. We found that once with a different watch. I hope this helps everyone!!
Nov 13, 2012 | Watches
How to turn of change engine oil light on 2011 ford focus
From FocusFanatics online - -
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
Jul 07, 2012 | Ford Cars & Trucks
After pushing the red reset button on a 1996 ford mustang does the button stay pushed in or pop back put
It will click after pressing and pop back up 99.9 percent of the time. this is in reference to a fuel reset switch .
Oct 16, 2010 | Ford Mustang Cars & Trucks
Lost OM, starting question - Homelite 10655 chain saw
The compression release should be a metal button that projects from the cylinder head and extends out from the cylinder cover so that it can be depressed before starting. There should be an immediate lessening of compression when pushed. If no such result, the release mechanism should be removed and cleaned, or replaced. Proper starting is to pump the primer button several times to fill the bulb with fuel, then set the choke closed, the ignition on and set the fast idle on the throttle. Pull the engine through several times until it pops, then release the choke part way, and try to start. Don't pull the throttle during this as it will release the fast idle setting. Once the engine fires, the compression release should self-reset for maximum compression. Hope this makes sense and helps!
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing lights
Hi, had the same problem today. Solution: Start engine, blower on max, air direction to cabin, press rear wiper and rear wash buttons simulanteously for 5 seconds (all lights now on steady). Calibration test starts and lights flsh alternately. After first test, AC and recurculation lights flash for the cool down test. If all test pass then rear wiper light blinks slowly (press to exit self test). If AC and recurculation test fails then just 2 lights stay on. To repeat this part of the test press just AC and rear wash simulanteously ( may take several attempts and usually best when engine is cold). Again exit by pressing the rear wiper button once it is the only one flashing (slow blink).
This does work but it took me 15 minutes to finally switch them off!!!
Jul 28, 2008 | Chrysler Voyager Cars & Trucks
Welding Tools Logo
180 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
