Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi big screen tv
My televison power button will not stay on i push it on it turns right back off. before i disconected it i was having problems different colors moving across the center of the tv
  • 2 more comments
  • pinchebuya May 10, 2008
    I have a 2001 Mitsubishi rear projection TV, VS-45609, that would shut off within seconds of turning it on. Several tries later, it would stay on; now it stays on when the power button is pushed, but the convergence of blue and red won't budge per the remote convergence protocol. I've tried converging the red/blue with the controls on the TV itself to no avail. Is this fixable?
  • vizion1 Jul 08, 2008
    I was watching my 1996 Mitsubishi VS-5043 50" Projection TV with my girl friend and when she placed a call on her Sprint cell phone the TV cut off. I tried to turn it back on but it cut off again. I continued to push the power button on the TV but it kept cutting off, so I unplugged it for awhile and tried to reset it but it keeps cutting off everytime I push the power button. I can't get the TV to cut back on. Do you think the cell phone had anything to do with it? And what do you suggest I do to fix it?
  • jcaputo Dec 01, 2008
    I inherited a VS-5043 and it recently began shutting off within seconds of powering on. I don't know if it is worth paying to fix or if I should just buy a new TV.
  • Anonymous May 04, 2009
    my 52 in mitsubishi tv just shot off and now it wont stay on
    Scholar:
  • 87 Answers
The VS5043 shuts down for many reasons. The most common are power supply issues. Bad caps, open resistors, shorted regulators, and missing voltages will cause the set to shutdown.
In my notesI have a location of components known to cause your problem( R5A03,L5A00,D5A21,Q5A04,Q5A03,C5A19,L902,IC900.IC700) All the parts listed are available. As I stated above there are many reasons for shutdown such as a bad flyback transformer that may not be available anymore. However, this type of failure needs to be properly diagnosed by a qualified technician. Good luck!
Posted on Nov 05, 2007
I was moveing a big scren tv model # VS-50501A. It was purchased in 1989. My problem is when I was moving it the filter screen on the front tore off and shredded to pieces. So far I have not been able to find a replacement, Can you help me?Dan @317-83-6815
Posted on Oct 28, 2008
I too have the same issue with my 5043 (1996) Mitsubishi TV. TV repairman says it's not repairable due to there being no new parts available by manufacturer. If you find a source for your parts please let me know. Good luck
Posted on Oct 01, 2007
SOURCE:
Why won't my Mitsubishi VS-50609 big screens power stay on?
There's a problem with the power supply or another board drawing too much power from it. It needs a service tech to determine which.
Jul 28, 2017 | Mitsubishi Televison & Video
Projection television
Loose wires or damaged contacts might be the problem, suggesting to call manufacturer for service support and for a servicer in your area.
Apr 29, 2008 | Televison & Video
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
No power Mitsubishi Big Screen
Sounds like the power supply went bad. Repeated on/off pushing of the buttons causes the set to go into shut down. If a part is marginal this is when it'll go bad. Usually a bad power supply part and will need professional repair. Please rate!
Mar 26, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
My Mitsubishi big screen tv will not come back on
Is the light blinking a certain number of blinks then pausing?All mistubishi have a diagnosis feature built in. Try pushing the input and menu buttons on the set and holding them both in for 5 seconds to see if it will blink a diagnosis code.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
2,201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
