SOURCE: Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
SOURCE: After moving from MI to
OK this is the problem which you see in more machines when not been used for a while.
you will have to prime the machine. As far as I know you can get warm water from this machine too. first decrust the brewing head as that can be one of the problems. if you still have the maintenance booklet it is picture 21 ( i think)
If this one is equiped with the warm water function press the hot water knob and let it run through. If not try to make a cup of espresso with fresh coffee. This should work
SOURCE: I need to descaler the
Do you know what works even better than vinegar? - Denture cleaner. Really! MA Dept. of Housing office has a heavily used group of coffee makers, and the secretary just drops one tablet in carafe and lets it clean overnight. Looks like new.
SOURCE: need a manual for a Krups Novo 3100 pro crema
You need to find the model number usually starts with FME.
Look on line at http://www.krupsonlinestore.com under customer service.
SOURCE: Need instructions for Krups Novo 3000 FNC211-42
You can download the manual here from Amazon.com, of all places.
In order to keep your Tassimo machine
operational at full order, it is important to descale it every three
months. Descaling products are widely available from stores that sell
coffeemakers and espresso machines. Be sure that the product you buy to
descale your Tassimo machine is intended for this specific use only. Mix
the descaling product directly in the water container, following the
instructions provided on the descaling packaging. Then replace the water
container on the machine. Place a large cup or mug on the cup stand,
insert the cleaning disc, bar code down and close the brew mechanism. As
soon as the AUTO light illuminates, press and release the start/stop
button. This will fill the brew cycle with descaling solution. Empty the
cup and let the machine stand for 15 minutes. Then open the brew
mechanism and close it again, leaving the cleaning disc in place. Repeat
this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water
container, rinse it well and refill with fresh, cold water. Clean the
machine by flushing water through it in the same manner and emptying the
cup as it fills. Make sure that all the descaling solution has been
completely rinsed away, and then flush two full water containers through
the machine before using it again. Remove the cleaning disc, rinse and
refill the water container and your Tassimo machine is ready to use.
Also, before you descale your Tassimo machine, always unplug it. Also,
never immerse the appliance in water and nor should you use abrasive
cleaning products or scouring materials on any part of your Tassimo
machine. This method works for most espresso machines,
including some of these popular models: the DeLonghi Magnifica
EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400,
Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi
PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
