Question about JVC Everio Share Station DVD Burner Burner
Keep getting incompatible disc error
Using JVC video camera with JVC CU-VD10; using Sony DVD-R but it keeps telling me incompatible. On page 4 of burner manual it recommends Sony DVD-R
  • conniebrad Sep 23, 2007
    already have tried....maxell, verbatim, and office depot brand. Sony, TDK and JVC are the recommended. That is why I went with Sony
    still no response other than try other brands - duh! isn't there something just a little more technical than that/
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things you can do/try (pls disregard if done): 1. Check disc compatibility - DVD-R (2-16X), DVD-RW (2-4X); 2. Check if disc is double layer. Double layers cannot be used if CU-VD10 is connected to either PC or camera (std are 4.7 Gb DVD, double layer are 8Gb disc); 3. Check disc size (8 or 12 cm). 8cm discs can only be used if connected to PC; 4. Use a CD lens cleaner; 5. Connect to a PC as an external DVD and try playing a known good DVD movie. If it can playback normally then presumably nothing wrong with the read function and therefore should read blank compatible DVDs. A possible temporary work around if problem persist is to download the movie from the camera to the PC then burn to the CU-VD10 as an external burner using Nero or other burner software. Hope this be of some idea/help. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 24, 2007
  • 54 Answers
What if you try other dvd-r brands. just a suggestion.
Posted on Sep 23, 2007
6ya staff
SOURCE:
Getting incompatible disc error everio cu-vd10
What speed disc are you using?
Use only $x, 8X or 16X -R or -RW
Oct 02, 2009 | JVC Everio Share Station DVD Burner Burner
Incompatible disc???
This device either needs a firmware upgrade or is actually faulty. It cannot be anything else.. Is it in warranty with JVC?
Jul 24, 2009 | JVC Everio Share Station DVD Burner Burner
I need a manual for a JVC Everio Share Station Direct DVD-Video Burner CU-VD10. i need manual also can anyone tell me how you connect to pc only have small end cable do i need different cable ?
Hello to connect this device to your computer you need a standard USB cable. You can get this from any computer store for cheap.
You can download the manual from here:
http://resources.jvc.com/Resources/00/00/91/LYT1571-001A.pdf
May 27, 2009 | JVC Everio Share Station DVD Burner Burner
Problem formatting the disks
Your burner has gone south. You can try a firmware upgrade to possible correct the issue but if that does not do the trick then the burner needs to be replaced.
Aug 19, 2017 | JVC Video Cameras
Incompatible Disc Message
You need to use -R DVD disks, I used Maxell 1.4X speed disks wih no problem in a CU-VD10 berner. Hope this helps
Sep 01, 2008 | JVC Everio Share Station DVD Burner Burner
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
JVC Everio Share Station DVD Burner Burner Logo
279 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Kim Halliwell
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
