Check charge first. Chec compressor for shorts, opens,grounds.
Match and replace compressor , if necessary . Obtained from any air conditioner /refrigaration parts store.
From what you have described it sounds as if the water line connection is not solid and secure to the ice maker. If it is leaking water and freezing surrounding items even more that would need to be addressed by a professional if you cannot find any issues yourself. You can try to turn the ice maker off, if it is equipped with a shut off arm or switch, and then look for any issues. You may also want to clear the freezer of items in that area and watch where the leak and new ice form to pinpoint the faulty area(s). Please let me know if you find anything additional out or if you need more help. Good luck!
Okay, is this unit hook up water to the Ice Maker?
If yes;
1, please check the water inlet and outlet and all solenoids valve connections.
2, there is a drainage and a drainpan see is the drain hose is in place.
need more details to solve the problem
feel free to email me at [email protected]
Hi!!! In order to make ice the freezer needs to be at 5-10 degree if not then you will not produce ice.The thermostat inside the icemaker will not start.If you see the water coming in and no ice then you have to invest in another icemaker.I hate them.Good luck..
