Question about Rowenta DX6700 Iron
Rowenta dx6700 we have had problems with the power cords on all our rowenta irons. it is only their otherwise superior performance that keeps us purchasing these irons again and again. now, our relatively young dx6700 is shutting off and on arbitrarily. the cord stabilizer failed almost immediately after purchase, but we taped it back and it worked satisfacorily for some time. now the iron switches off and on without for no reason. the power cord is intact, not frayed. is this a switch problem and can we fix it this time instead of having to fork up another $70 or so for another? thanks! we're ready to give up on rowenta!!
  • 6 more comments
  • Anonymous Nov 05, 2007
    I am having the same exact problem!!! It is so frustrating because I love the iron - but have never forked over $100 for one before. I haven't even had it a year... and the cord is shot! What to do?
  • bigdogman Nov 15, 2007
    It appears that when the cord is moved back and forth at the connection or the swivel point where the cord connects to the iron it will turn on/off. Is there a fix for this problem? I see other users of these irons are having the same problem. Could it be the connection at this point that has worn or become loose?
    George C.
  • Utah Man Dec 24, 2007
    I have the same problem. Just toggle the cord seems to fix it temporarily. Think I'll tape it up like you and switch brands next time. Can't get into it.
  • Stan F Dec 31, 2007
    The problem described here fits ours exactly. And I cannot find a Rowenta service center on their website. When it comes to service via their website ... good luck.
  • susiesparky Oct 11, 2008
    My Rowenta is a GREAT iron however the power cord started to turn on and off randomly after a few years of use.  Now the cord has begun to spark when I use the iron, I have since looked inside the cord (cover) and found that the wires have separated on the inside.I hate to buy a new $100 iron when I know it is just the cord that needs repair.  Suggestions would be appreciated.
  • Roland Wong
    Roland Wong May 11, 2010
    Looking at all these problems, I would like to think that FixYa website helps support many manufacturers by airing these problems and finding solutions.
    Rowenta USA website: http://www.rowentausa.com/ as a courtesy, but I think now that you all know where they are please contact them.
    By the way, everyone I know who have had a Rowenta irons have been pleased with them. Their DG-980 has the performance of a commercial product w/ some low cost e.g. fragile consumer level components that break. This problem appears to be a latent defect and with so many with the same problem, should get their corporate attention.
    FYI, this is an excerpt from their FAQ/Troubleshooting section regarding AutoShutOff (or the intermittant ON/OFF problem).
    "Many of our irons are equipped with an auto-off feature. This feature will engage if the iron is left on its heel for 8 minutes, its soleplate for 30 seconds or on its side for 30 seconds. If the auto-off feature engages, shake the iron gently to turn the thermostat back on. The auto-off function is not an on/off switch. Please unplug the iron when it's not in use."
  • Anonymous Mar 21, 2014
    Power cord needs replacing
    my cord was pulled out and did NOT retract. I do NOT have a problem with leakage. I just want my reel retract fixed
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
SOURCE:
My iron just stopped working,there is no power.
Could be heating element or power cord, if needing more assistance let me know...easy fix if you know electronics
Feb 28, 2014 | Rowenta DX6700 Iron
Partially cut wire in cord
Irons take a lot of electricity to run, if the cord is damaged, you should not use it and you may not be able to get another cord for it. IT would be better to buy a whole new one.
Feb 20, 2014 | Rowenta DX6700 Iron
How do you clean my rowenta focus iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
heatman101
Oct 30, 2010 | Rowenta DX6700 Iron
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
My dog chewed the cord to my Rowenta Iron
Yes, but not warranty covered.
Check your local yellow pages (yes, printed book) for an apliance repair shop (look for discount coupon in back while you are at it).
Does not have to be an "authorized" Rowenta shop ($20). Get an 8 foot cord if you think you need a longer cord.
The dog can be fixed, too: (I couldn't resist typing that) Wipe some "training spray (pet shop or WalMart $5)" (harmless to dog & environment) onto the new cord (NOT ON THE DOG) to train the dog to leave it alone.
Sep 21, 2009 | Rowenta DX6700 Iron
My new iron does not steam while I am ironing
Try using different water...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Aug 24, 2009 | Rowenta DX6700 Iron
Iron won't stay running. I'm pretty sure it's the cord because if you move the cord the power is restored. Would a new cord solve the problem and where do you get a new cord?
With modern iron it can be difficult to renew the cord due to the special screws they use when making them. It does sound like the power cord is damaged. It may be cheaper to buy a new one from wallmart or similar store.
Jul 29, 2009 | Rowenta DX6700 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
I have a rowenta iron. When I am ironing the
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Rowenta DX6700 Iron Logo
1,556 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
