Question about RTO Spi-dog Red In Box Idog Spider Man
I had this Idog for a year and the battery was corroded and it won't work should i buy a new one?
    President:
  • 1,489 Answers
Usually, if the corrosion is not that extensive, this problem can be fixed by sanding (such as with an emery board) the contacts in the battery compartment and cleaning them with rubbing alcohol.
Posted on Apr 22, 2009
I can't get my techpet to wirk
Instructions
    • 1 Check that the iDog is powered on if it doesn't respond to your commands. Press its nose to activate the toy.
    • 2 Verify that the iDog has fresh batteries installed if the dog doesn't turn on. Use a Phillips screwdriver to open the dog's battery compartment, located on the its right back leg. Insert two new AA-sized batteries according to the "+" and "-" symbols listed in the compartment.
    • 3 Inspect the iDog's connection to your iPod if it doesn't move and dance to your iPod's music. Plug the iDog's connector cable into your iPod. The cable end labeled "B" gets inserted into the headphone jack on your iPod. The opposite end goes into the front left leg of the iDog.
    • 4 Make sure your iPod is powered on if the toy is connected to the media player and is turned on, but not moving to the music. Your iPod may need recharged by connecting it to a computer with its included USB cable.
    • 5 Reset the iDog if it continually freezes or stops moving in the middle of a dance. Use the tip of a pen, paper clip or similar thin object to press the reset button located on the bottom of the toy's head.
Jan 20, 2013 | Toys
I want to buy this for my daughter for Christmas. Can it be connected to the idog so that it can play through the idog's speakers?
Yes if this has a headphone out it will work with idog.Will need cable to connect between the two.
Nov 11, 2010 | SanDisk Sansa Clip MP3 Player
My idog will not turn on. i just replaced the bat...
Try plugging in your iPod and playing music worked for me and/or put new batteries in it but do NOT press reset
May 20, 2010 | Hasbro I-DOG AMP'D
Idog
Please take a look at this PDF file it has the instruction included for the I-dog. http://www.hasbro.com/common/instruct/I_Dog.pdf. I hope this helps please let me know and I will try to find something else for you.
Thank you
May 05, 2010 | Hasbro iDog Electronic Pet Dog
I got my iDog from a friend. I took the batteries out and there was a weird white powder. I put new energizer batteries in and it won't turn on. What do I do?
It sounds like the battery leaked. First, disolve some baking soda in water and carefully and as dry as possible, wipe out as much or all of the residue. Attempt after a few hours of drying to re-insert fresh new batteries and see if it turns on. If not, I would save the leaked batteries in a baggie and contact the battery manufacturer via carrier mail and explain that the batteries leaked in your device and it will no longer work and you would appreciate either a repair or replace. Most times if you have the bad batteries and mail them in also, they will either reimburse you for the product if they are not able to repair it. I know this has worked for energizer and rayovac batteries. Be civil and professional in the letter and I bet you get some resolution. Good Luck and hope this works for you. Actually, before cleaning the product, you should probably contact the battery company first if possible so the proof is still in the iDog. Good luck
Dave
Aug 09, 2009 | Hasbro iDog Electronic Pet Dog
I lost the manual to my idog amp'd and don't know how to replace the batteries because i can't find the compartment
Under the iDog AMP'D "Backlegs" there should be two screws. Unscrew them (Lefty Loosy, Righty-Tighty) and replace the batteries with three "AA" batteries. Hope this helped!
Jul 24, 2009 | Hasbro I-DOG AMP'D
How to charge a idog
You don't "Charge" iDog AMP'D, you change the battery pack located under it's hind feet. When your iDog does the intro when you turn it on every five seconds, that means it's time for some new batteries!
Jun 28, 2009 | Hasbro I-DOG AMP'D
Idog keeps dying!
The idog should not do that and i suggest returning it or exchanging it for another one.
Dec 31, 2008 | Hasbro I-DOG AMP'D
Idog hasn't been used in awhile.. Does it charge like an ipod?
You cant charge you just have to use batteries
Nov 12, 2008 | Hasbro I-DOG AMP'D
Amp'd turns on but turns off after intro.
I had this problem too, I was going crazy and worried about it, your iDog AMP'D Just needs new batteries, to change it, unscrew the metal screws that are located under it's back legs, and replace the old batteries with three new AA ones. Make sure they are good batteries!
Hope this helped!
Oct 16, 2008 | Hasbro I-DOG AMP'D
RTO Spi-dog Red In Box Idog Spider Man Logo
202 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
