I have reviewed the instructions many times but this camera will not alow me to finalize the disks the finalize option appears in black in the menu
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
PLUGGING IN THE ADAPTER WORKED!!!
WOOHOO!
I guess they don't want to risk running out of battery during finalisation (may kill the disk)
Thanks "Guest" owe you one..
I found that I had to use the viewfinder in order to get the disk to finalize. Using the screen didn't work -- I kept pressing 'finalize' but nothing happened. Then I remembered reading somewhere that you have to close the screen and use the viewfinder, which I did. Voila! It worked (finally!).
SG
No solution. Same problem. There seems to be a problem lurking with the Canon DC210 in regard to finalizing. (It was plugged in.)
Remove battery, plug in elect, finalize.
In order to finalise disk first plug ur camera then put it in "P" mode if it is on auto and don't shake the camera
Make sure you pt it in playback mode and make sure its plugged in i had same problem it didnt give me the finalize option untill i magically put it in playback mode then presto the option comes up so make sure you put it in playback mode by pressing down on the on/off button
Plug in the adapter
THNX !! It worked
I am having the same problem the option to finalize is not on the menu
i am not getting to fil\nalixe my dvd
yes... my problem is the same... i've recorded all the disk but i am not getting flninalizing it... what do i must do??? Thanks
Ditto
I'm having the same problem but finalize is not on the menu.
I have dvd -rw on VR mode on my cannon but I dint finalize the disc , my question if I insert the disc to watch on my camera the disc will erase?
I've lost my owners manual and cannot finalize discs. Plesae help.
finalize option blacked out
I have a canon DC210, I'm unable to finalize on the disc, that option seems to be disabled or greyed out. Can someone help?
I can't finalize the disk in the disk operation. It delete all image.
Help me please.
HOW DO YOU UNFINALIZE THE DISK?
how do you unfinalize the disk?? i can finalize no problem but not unfinalize iv tried plugging in unplugging erasing disks initializing but nothing will work and unfinalize remains blacked out?????
i havee dvd - r and i cannot finalize it just does nothing when i press it
Have the same problem and looking for any options.
Thanks! "Finalize" didn't light up in White until I plugged it in.
Once I plugged it in then I was able to Select/Highlight it and finalize disk.
Thanks!
I have it plugged in but finalize does not come up on screen, only initialize.
i can not finalize a disc, I have it plugged in but it does not come up on the screen only initalize
I have read that the AC battery charger needs to be plugged in, which I have done but it is now not showing as an ioption at all. Just Disk Info and Disk Initialize (greyed out).
I can't finalize the disc for the Canon DC210 camcorder? Please help!!
after the complete the disk i want to play the disk in my dvd player. when i remove the disk that time i read a massage in screen the disk must finalize for playing in any player. i want to know how to finalize the disk i saw the option but i cant able use. pleas help me how to play the disk in dvd player
