Question about Garden
Fuel pump for burnner
Fuel pump is bad need new one model#7176 can you help me.
My fuel gage says I'm on E when u just feeled my gastank, how do I fix it?
1st you have to figure out if it's the gauge in the dash that went bad, a bad wire or circuit in the dashboard cluster or if it's the fuel sensor on the fuel pump itself. you don't say what year or model your car is so you can't get much help.
Mar 22, 2017 | Cars & Trucks
New fuel pump and filter, car starts but dosent throttle up
Need to know what you are working on. Some late model "fly-by-wire" cars have bad throttle pedal units that can do this. Also check actual fuel pressure as many parts store pumps are bad even when new.
Oct 21, 2016 | Cars & Trucks
Truck turns but won't start and can't hear fuel pump engage
It could b ur fuel pump went bad or it could b ur fuel pump really just take a nuther out ur fuel pump rely an put another one in its place if the file pump turns on u no that u need a new relay if it don't kick on then u need a new fuel pump I hope this helps u out
Oct 01, 2014 | Cars & Trucks
Car wont start
replace fuel filter.listen for fuel pump operation with ignition switch on position for 3 seconds should hear fuel pump running should have humming or churling noise if so fuel pump working if hear no noise fuel pump faulty or could have blowed fuel pump fuse or bad relay.if fuel system okay problem could be ignition timing off due to worn broken timing belt.could have faulty ignition module.bad crankshaft sensor or camshaft sensor best to have vechicle code scan first before buying alot of new parts.could have bad ECM. many things will cause no start problems i.dont know model type vechicle.could have bad spark plugs wires. distributor cap and rotor could be bad.ignition coil could be bad.
Mar 28, 2013 | Cars & Trucks
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Is the fuel pump on a 1989 GSR galant servicable? this one seems blocked.
This fuel punp is not removed by dropping the take like so many. It is under an access panel under the rear seat. To change the fuel pump follow these instructions.
1. Determine which fuel pump your Mitsubishi Galant will need. This depends not only on the make and model, but also the engine size.
2. Prepare your car for service to the fuel pump. Relieve the fuel system pressure and disconnect the negative battery cable with a socket wrench. Take out the rear seat cushion. You will need to pull the seat stopper out and lift up the lower cushion. You can now remove the access cover.
3. Unplug the fuel pump's electrical connection and disconnect the fuel send and return hose. Remove the retaining cap for the fuel pump with tool MB991480 and remove the fuel pump.
4. Install the packing material on the fuel tank. Replace it if the packing material is damaged or deformed. Install the new fuel pump and align the marks on the floor pan and fuel pump.
5.
Complete the installation by reversing the removal procedure.
This should take care of you. Let me know if this helped you.
Mar 07, 2011 | 1989 Mitsubishi Galant
Oven burnner comes on but never seems to fully ignight or get to preheat temp. and i can smell gas,broiler and top burnners working fine
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 10, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Truck idles and runs fine when slowly accelerating. when power is needed for merging motor (350) has stalling problem (doesn't kill though). New fuel pump and filter installed.
if it's a fuel injected the it's your fuel reglater that's going bad...but if it's a carb. chevy then the flote's need to be reajusted to the right setting...hope this helps and good luck..
Nov 13, 2008 | 1998 Chevrolet C1500
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
