Question about GPS
I used RegCure Registry Cleaner and now my F: drive (dvd) is gone or replaced by a K: drive which I never had before.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 110 Answers
Ther was not a problem u can change drive later please follow the details
1> go to run type diskpart
2> in command window type list volume
3> there u will see yours dvd drive the letter
4> please note drive volume no. Eg. 1
5> then type select volume the no Eg.
select volume 1
6> u will see "Volume 1 is the selected volume."
7> then type assign letter F press enter
8> u will see "DiskPart successfully assigned the drive letter or mount point." msg
Its done u r dvd drive will name F now
Posted on Apr 22, 2009
Will not let mr reinstall after crash
Use an uninstall program to make sure there are NO files in the registry that load this program....I recommend RegCure...ALWAYS BACK UP YOUR REGISTRY BEFORE MAKING ANY CHANGES !!
Aug 29, 2014 | 321studios 321 Studios DVD X Copy (Backup,...
Tip
How to Erase RegCure from your pc system
<span><span> <p>RegCure is a registry repair tool that allows you to solve registry errors, such as missing dll files, damaged registry keys and corrupt settings. If you are no longer interested in this program, or prefer to install and use a different registry repair tool, uninstall RegCure from your<span> </span><a href="http://www.ehow.com/computers/">computer</a>. Uninstalling RegCure is a quick and simple process for Windows 7, Vista and XP users.<span></span><br /><br /><span></span> <span>Instructions</span> <ol> <li> <ul> <li><span>1</span> <p>Click the "Start" menu and then click "Control Panel." Click "Uninstall a Program" if you are using Windows 7 or "Programs and Features" if you are using Vista. Double-click "Add or Remove Programs" if you are using Windows XP. The programs window will launch.<br /></li> <li><span>2</span> <p>Scroll down and click "RegCure." Click the "Remove" or "Uninstall" button. If prompted, enter your administrator password and confirm you want to remove the application. The setup wizard will remove the program.<br /></li> <li><span>3</span> <p>Restart your computer to complete the process<br /></li></ul></li></ol></span></span>
on Dec 27, 2010 | Computers & Internet
Cd drive not reading disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
http://www.nextag.com/dvd-lens-cleaner/shop-html
http://www.infopackets.com/news/hardware/2005/20050315_clean_cd_or_dvd_rom_lens_with_a_brush_part_2.htm
Mar 23, 2014 | E-Machines emachines (emachinees) CD-ROM...
HP 740 cd/dvd not reading disc
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it http://www.nextag.com/dvd-lens-cleaner/shop-html
Feb 20, 2013 | HP ScanJet Computers & Internet
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
Slow speed
One way to make it run faster is to defrag the HDD. Go to Start->Control Panel->Admin Tools->Computer Management. here select Disk Defragmentor and then select your C: drive. Defrag it and then defrag the others too. You would find a marked difference in performance. Second way is to use a Windows Registry Cleaner. What happens is that with you installing and uninstalling programs, a lot of file bebris is left in the Windows registry. And the system has to read the registry very often, thus wasting a lot of time on things that are not there. If you search Google for Free Registry Cleaners, you will find many. Use it and trim the registry and you will find a tremendous difference in speed. My laptop used to take 40 minutes to boot at times till I cleaned the registry. Now it gallops like new.
Nov 20, 2009 | ASUS P4B266 Motherboard
Error 1706
Try to use the Registry cleaner software e.g.
Registry Cleaner or RegCure
these two softwares should help you to remove the unwanted registry entry which are raising the problem of "Error 1706"
May 30, 2009 | Microsoft Windows XP Professional for PC
CCleaner
RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>> http://www.ccleaner.com/
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM cpenny29@yahoo.com
Oct 24, 2008 | Microsoft Windows XP Home Edition
Product Key for Active @ Undelete
For GUEST!:
RegCure™ (from ParetoLogic®) provides fast and efficient scanning and cleaning of your registry so that your computer can run at an optimal level of performance. RegCure identifies invalid registry items and you decide what items you want to remove. After removing registry entries, you have the option to restore your computer to a previous state.
Protect your investment and ensure maximum PC speed and performance with RegCure registry cleaner. Compatible with all Micro$oft products and third party applications, RegCure seeks out and repairs those issues in your registry that lead to poor performance such as remnants left behind on your registry from failed installations, incomplete un-installations, disabled drivers, and spyware applications.
RegCure enables you to fix your PC's windows registry in the way that is most comfortable for you. Clean your registry manually according to your own specifications or perform a thorough scan and clean it automatically!
The user-friendly interface allows you to monitor the progress of your scan, schedule RegCure to scan at the times that are best for you and will even manage and clean up your start up programs for you if you wish.
Download:
http://rapidshare.com/files/71005630/RegCure_1.5.0.0.rar
Dec 05, 2007 | Computers & Internet
Cd\dvd drive won't read software cd
Just a suggestion, try to update your drivers.. If you have installed any third party cd burner just uninstalled it. after uninstalling, clean the registry via ccleaner, regcure, or any other 3rd party cleaner... then update your drivers... most of the 3rd party cd burner software are damaging your cd drivers...
gud luck
Sep 27, 2007 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
GPS Logo
67 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
