Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
I don't get HD quality pictures. And it just shuts off for no reason. Am I suppose to get HD channels?
  • Samsung Master
  • 3,866 Answers
Are you on a actual HD channel? If you do not think you are getting Hd then try this hook up a dvd then select the 480I function and see if that works..
Posted on Apr 22, 2009
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Satelite Dish
please tell the model number please.
reply.
Oct 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
What does HD ready mean? Is my Sony Bravia LCD acctually an HD TV or not?
High definition ready is different to Full High defintion for the simple reason the software is different to prove play a HD play station game on both and you will immediately see the difference in picture quality however the difference is not so significant on your normal satellite HD channels depending on the resolution the TV can produce
Nov 23, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
I have a 1080 with 120 and my picture is not clear. If it's not a hd channel it really is terrible and if it is hd channel it still is not in full focus. The picture is not sharp. I am really disappointed...
I am assuming your set is new. Ask for it to be serviced under warranty. This sounds like your set is defective for some reason.
LCD TV sets are known for their exceptional sharpness and performance when having a good quality signal source, and especially with an HD programs.
Jerry G.
Nov 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
Aug 13, 2007 | Sony KDF46E2000 46" Projection HDTV
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
