Question about Canon PowerShot S3 IS Digital Camera
Displays "lens Error"
My S3IS camera shows Lense error on display when I start the camera and then shuts down
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
My lumix dc20 when turned on displays this battery cannot be used. Any ideas please
1) Incorrect battery, use genuine battery. 2) My Canon 400D had a similar problem. Checks showed that I had a damaged standard 18mm to 55mm lense unit, and also gave me "change battery" error message. I had a similar problem with a 70-300m lens. The camera main lense needed repairs, the Tacumar lense was not worth repairing. Have a camera specialist check your camera and more specific the main lense unit.
Jun 08, 2014 | Cameras
My canon ds6041 displays err 99 when i try to capture light aur object in sun light.What should i do i'm using 70-21-mm lense
Usually this is cased by shutter failure or failure of the aperture unit in the lens. Try another lens and see if you get the same error message - that will tell you if the problem is in the camera body or lens
Apr 05, 2013 | Canon Digital Rebel / EOS-300D Digital...
Canon 30d with tamron af 70-300mm di macro lense showing error 99
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Jul 12, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
My cannon rebel eos DS6041 displays error 99 when
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon PowerShot A460 displays Lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 29, 2010 | Canon PowerShot A460 Digital Camera
Lense error on sanyo s1070
Your len's mechanism is jammed or damaged internally. You may try resetting it, it might or might not work. If this fails, it will be cheaper to buy a new camera...hopefully this helps!! Please rate...thanks
Aug 05, 2009 | Cameras
Lens error in S3IS
Apr 22, 2009 | Canon PowerShot S3 IS Digital Camera
Lens Error
I solved the problem with a recommendation Rob posted here on FixYa. Some air pressure blown around the lens and it worked. Thanks, Rob. You're my hero! I almost sent the camera in for repair.
Apr 08, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
216 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
