Question about Curtis CM19102 19" TV
Focus TV was on - went to kitchen and upon return the TV was blurry. Now I am unable to bring it back into focus again. The writing is more blurry than the picture. When there are shows on that have the writing fade in and out then there is a point where the writing is clear for a split second.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The writing is more blurry than the picture. it is not that serious while shifting 1 focus wire might be loose. 2 crt base loose. 3 dust like thing near focus wire. 4 adjust focus control fitted on eht. caution it is high voltage portion do not touch unless you know about it.call tech to do it. good luck.
Posted on Sep 23, 2007
SOURCE:
Mitsubishi ws-55515 intermitent blurry picture
A bad connection somewhere--when it happens if picture is 3d look in menu for convergence and call up the grid of lines--if they are not perfect you have convergence issue which usually requires parts to be replaced.
In this set sometimes the chips will become flaky and convergence will jump in and out.
May 05, 2012 | Televison & Video
Unable to boot up computer it keeps returning to set up
Set the machine up as normal entering all your information such as new account, networking etc and upon reboot it brings you back to setup again I suggest you do a full format of your Hard Drive and then a full reinstall of Windows and this should sort the problem out.
Oct 19, 2009 | Computers & Internet
When I turn on my rear projection tv the picture is fine, then all of a sudden it goes blurry, after about 45min you turn it off and then back on and the picture is fine. what could the problem be. the...
well if your tv was to be a normal tube tv, i could suggest to check your crt socket. in this case its projestion tv, so your are having three crt sockets. the main problem is with your main flyback transfomer. try to change the flyback and it should work back to normal. other way to test is try to adjust your transfomers focus, if it is adjusted, and goes blury again, then you need to change it,...and try to re-service the board...best luck
Oct 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blurry tv
there is a focus control in the front of the set behind the front grill there is a door in the middle attached by screws take this off and it should be right behind it. There are six controls on a little box one row says focus and the other says screen don't adjust the screen controls. In some cases these are in the back of the set.
Aug 07, 2009 | Sony KP-65WS500 65" Rear Projection...
Hitachi 57F500 blurry picture
its the convergence problem in your tv.the ic needs replacement.to fix the problem.its worth getting it fixed.get it repaired.
the cost will be negligible.
Mar 21, 2009 | Hitachi 57F500 57" Rear Projection...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Television - blurry
if you know to adjust the focus at the back of the plyback,the upper knob adjust it .if there's no effect, change the CRT socket,the white socket with many pins at the back of the picture tube
Oct 11, 2008 | Philips Televison & Video
Picture blurry
What was replaced by the repair shop? The blurriness may be out of focus. If so, the focus is controled by the flyback transformer. That connects to the picture tube at the top (anode cap).
C-Dog
Feb 13, 2008 | RCA F36450 36" TV
Actually...it's a Akai PT5299HD
I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
Jul 31, 2006 | Akai PT5598HD 55" Rear Projection...
Curtis CM19102 19" TV Logo
101 people viewed this question
Top Curtis Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
