Question about Insignia IS-PDO40922 Portable DVD Player
Insignia portable dvd player: disc not spinning
Hi, I insert a dvd, the screan reads "loading" for longer than usual and then I get a "no disc" message. When I pop it open, the disc isn't spinning, or is spinning very slowly. The unit was working fine this afternoon. Any suggestions? [I've turned it off/on (and waited a bit) many times, and tried different dvds -- to no avail.] Thanks in advance!
  • 5 more comments
  • ixony Sep 23, 2007
    Thanks for your help, Simplemitch. Is this a normal a result of usage? Or due to flawed manufacture? I'm considering buying a Toshiba ($200) and wondering whether the same thing would eventually happen (possibly not so quickly). Any thoughts?
  • italian_tank Dec 21, 2007
    i put a good DVD in and now it just reads loading and will not say no disc just keeps spinning and saying loading... need some help thanks
  • Anonymous Feb 09, 2008
    I was playing DVD-R copy and it stopped and after that it say loading for more than normal time and in the end says no disc. This is happening with original dvd too.
    I HAVE THE SAME PROBLEM, and I doubt it is from over use as it has probably seen 10 DVD's tops. I believe the problem is ( they are just crap). Hope this helps, I myself will never buy another Insignia product and it is very doubtful I will purchase anything from a store that sells Insignia products.
    Insignia portable DVD player. Played fewer than 100 hours, almost certainly. Started by freezing during play, then will not load discs, instead spinning for a while, and then claiming "No Disc." I have tried blowing off dust from the laser lens/cover with a photo bulb. Of course, I have tried a number of discs. I will not buy another Insignia product, unless I find a solution.
  • Anonymous Mar 26, 2008
    disc will spin for along time, will say loading but never happens, won't play.
  • Anonymous Jan 06, 2009
    mine will not load but when it does it freezes in the middle of a movie
  • 752 Answers
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
  • Mitch
    Mitch Oct 06, 2007
    It's a bit of both. They are designed poorly so they wear out unusually fast. I haven't used the Toshibas to make a judgement, but I have had REALLY good experiences with the Sony models.
It could either be that the laser has become damaged/ worn-out; or all you have to do is plug your DVD player into the charger, leave it there for a few days & then turn it on & test it. Otherwise, it would be in your best intrest just to take it to the store you bought it from.
Posted on Apr 28, 2008
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
Hi my portable dvd player by insignia won't read
Try using a lens cleaner. Also, reset the unit to factory defaults. Ensure that the disk you are attempting to play is clean and scratch-free. If the problem persists, you may pursue service options through the place of purchase.
Jun 20, 2010 | Insignia NS-PDVD10 Portable DVD Player
Dvd wont load
Try multiple store bought dvd's if all of them don't work then the dvd drive will need to be replaced. Usually the manufacturer will replace it instead of repairing. Repairing is usually as expensive as just buying a new one.
May 07, 2010 | Insignia NS-PDVD8 Portable DVD Player
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
No longer loading dvds
You may have a bad laser. First, make sure the laser assy. travels back and forth easily, then make sure the table the disc sits on spins freely. If it still isn't reading, load a disc and immediatly flip it over to it's top and see if it works. Working or not, still a bad laser.
Feb 12, 2009 | Audiovox D1708 Portable DVD Player
Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Nov 29, 2008 | Insignia PD10135 Portable DVD Player
Do other DVDs work? Try a music CD to see if it will work. If it does not work, then the Laser pickup unit is failing and will cost more to repair then replace the whole unit. Sorry for the bad news.
Thanks for reading!
May 01, 2008 | Insignia NS-PDVD9
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
Insignia IS-PDO40922 Portable DVD Player Logo
502 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
