Question about Microsoft HP Compaq Presario F553US Notebook
Compaq Presario F500 Monitor Problem
I've been using my laptop for almost 2 years now and I'm having problems with my monitor. There are times where I turn it on and the monitor displays nothing, just blackscreen, so what I do is just turn it off by pressing the power button long enough til the power turns off then i turn it on again. I do this for more than five times or so until its turned on properly.
So, I asked a friend some advice and he told me that my laptop needs to be reformatted, so I let him reformat mylaptop. But the worst happened. Now, even if I try to turn on my laptop for how many times, it doesn't work anymore. No display.
I don't know what to do. I tried to ask a repair shop to check it and the technician told me that i need to get a new motherboard. But, again, someone told me that laptop's motherboard doesn't get broken. What do you think?
What should I do?
  • Microsoft Master
  • 32,281 Answers
You need to determine whether the fault is the video/motherboard or the LCD screen on your laptop.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 22, 2009
Go to hp limited service enhancement to determine whether your computer is eligible for a free repair.If your product number is listed hp should repair and return your notebook within 10-14 days for free.
Posted on Feb 10, 2010
Same here ... the same problem too
Posted on Apr 29, 2010
I had the same problem on my laptop and eventually the screen wouldnt come on at all i have a (compac) laptop i went to a local computer repair shop and he said it was the motherboard my computer is about 4 years old and was out of warrenty but i called up compac and they said that the mother bored was stuill under warenty so i sent it in and they fixed it for free even though the warrenty was up
Posted on Sep 15, 2009
Hp presario f600 boots and runs but screen wont cut on
Well if you are sure the computer is running, then you could have a bad inverter, take a flashlight and shine it on the screen, if you see the icons and computer booting, then you have a bad inverter, go on amazon and order another LCD. also if you have a desk top monitor, connect the monitor to your laptop, then boot up your laptop, hold down the "FN" (function) button and press "F4", you should see everything on your desktop monitor. Good luck.
Feb 15, 2014 | HP Compaq Presario F500 F700 and G6000...
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
How to install a exterior monitor on a presario F700
1plug in monitor 2.right click desktop go to properties (on XP) or screen resolution (on 7 or vista) you should see two boxes labeled one and 2 double click 2 that's you monitor...on xp in the properties window go to settings tab to find that option, if it does not show up reset your computer with external monitor plugged in and repeat process if necessary if that doesn't work you need to update driver for your graphics card/chip
Apr 09, 2011 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700--the display on the monitor is mostly black or snowy, but when I plug in an external monitor, the external monitor works as it should. So you'd assume the screen is bad, right? I...
no photos, no joy
why post lacking the look, as your topic is all 100% Look.
a 2007 note book
the year or close to the year they made Nivida chip solderball , GPUs, that all fail.
so if its got that its, doomed, and buy 3 more used mobo
and all doomed sure
the screen is just a LCD screen and a backlight
if the digital data to it is bad (GPU) then the GPU is bad.
and hits soldered down,,,
buy desktop next time, and its child's play fix.
pop a new card
or and HP 9540w, that has cards !@!! and dont FAIL.
Oct 26, 2017 | HP Compaq Presario F500 F700 and G6000...
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01480071&dlc=en
This might fix your problem. There is a problem sith the bios on select F500 models. Yours might fall in that category.
Aug 29, 2008 | Compaq Presario Notebook
Compaq Presario 6000 Monitor Problem
sounds like your lcd screen is on it's last legs...time for a replacement..
Jun 01, 2008 | HP Compaq Presario V6000T Notebook
Dark screen of compaq pressario desktop monitor-some time works by just shifting the monitor a bit
the light guns inside of a monitor can weaken with long use..also, the screen itself can lose it's phosphor coating as well..
your service person is correct
Mar 20, 2008 | HP Compaq Presario V2000 Notebook
Microsoft HP Compaq Presario F553US Notebook Logo
3,218 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
