Instructions i am having problems tuning my tv channels into my video, i was wondering if you can help me. i have a dvd video combi which the model number is dv pf4e
  • 150 Answers
No problem, Follow the below link for the manual http://safemanuals.com/user_guide_instructions_owner_manual_HITACHI_DV-PF4E(UK)_E.htm Have a good 1.
Posted on Sep 23, 2007
SOURCE:
Bought a new 32inch tv with added freeview. I have a ferguson dvd/vcr combi which has tuned channels 1 -5 ok but how do I tune the digital channels
You're going to need to use your menu button and do a channel scan.
When it completes use the save option if present and exit the menu.
Mar 11, 2010 | LG Televison & Video
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
Television will not program channels 2-7
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
Oct 09, 2006 | RCA F27669 TV
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Ekse
