Question about HTC Touch HD Smartphone
Time changes by itself
My hd change time by itself
Have you tried changing the time zone of your unit. or maybe you have enable auto update of date and time that is why your having problem o your smartphone. Try it.
Posted on Apr 22, 2009
Clock change to british summer time on kndle fire hd
To change the timezone.
Step 1: Pull down the upper status bar, More +
Step 2: Select Date and Time
Step 3: Select Timezone - change to the correct Timezone
Mar 31, 2013 | Amazon Kindle Fire HD
Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Jul 04, 2008 | Dell W2300 23 in. HD-Ready LCD Television
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
Dec 01, 2009 | DISH Network ViP 612
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Hd problem with xbox 360. works through SD but black screens on hd channel. i took xbox upto friends house who has 1080p tv but never changed the setting when i put back to my tv. would this be the problem...
Thats the problem sometimes the Xbox360 can change that by itself but in your case i think your best bet is changing it back with your friends HDTV. Also i would try hooking up the cables one more time on your tv but make sure you turn on your xbox after all the cables are connected. But its nothing major its a really easy fix. good luck and let me know if you still have the problem.
Oct 02, 2008 | Video Game Consoles & Games
Polaroid 23" HD LCD TV
You need to select auto channel find from your tv menu
Aug 31, 2008 | Polaroid Televison & Video
TV keeps changing channels by itself
Either the channel up or down buttons on the tv are most likely stuck.
Aug 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
No one seems to have an answer
Problem with the vertical linearity..some electronic component in vertical circuit gone bad..probably, a dried up electrolytic capacitor..usually 100uf/50v.u need a serviceman to fix that.thanks,hope this help u
Feb 07, 2008 | Televison & Video
HTC Touch HD Smartphone Logo
185 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
