Question about HP Compaq FS7600 17" CRT Monitor
Monitor settings I was trying to get a wavy verticle line off my monitor screen and changed something in the front controles that reduced my display down to half and I can not get it back to full screen.
    President:
  • HP Master
  • 2,022 Answers
Try to adjust with the panel button . bye
Posted on Sep 25, 2007
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Samsung LD220 - background (plain blue) has continuous horizontal wavy lines that move up the screen. As if straight water ripples are going up screen. But, pop-up windows display fine since they are...
There may be a few issues her, try changing the contrast andbrightness of the screen, this can be done by using the buttons on the monitor,check any documentation you have if you're having trouble. If this doesn't fix it could be a monitor problem for your videocard itself. Try using another monitor,if possible, to test your video card or try your monitor on another pc/laptop. If the monitor works fine on another machine then chancesare it's a problem with your video card, it may even need replacing.
Mar 02, 2011 | Samsung LD220 22 inch Monitor
Screen is wavy and writing hard to read. We changed monitator
Sometimes this problem is produced because the screen is set up to a display setting to high for the monitor, and there are wavy pictures, and almost impossible to read.
Other trhan that, could be a bad monitor cable.
Hope this helps
Jul 04, 2010 | Microsoft Windows XP Home Edition
My monitor is verticle, won't flip back to
Try to use Cntl+Alt+Arrow keys to rotate the screen. Also go to display settings and change the monitor DPI setting will also resolve your problem.
Thank you for using Fixya.
Apr 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The picture my monitor has a wavy effect and I've tried to get it back "square". What do I do?
kdoran121, Some component part has failed inside your monitor!! Possible verticle drive signal is "bleeding" into the horizontal signal is causing your "wavy effect" to occur on screen. Electronic technician will need to troubleshoot problem down to "component level" to solve monitor problem. That's my best guess on this one. You could try to swap-in a known good monitor to your pc, just to prove that the monitor is the problem and NOT your pc!!! Yes, I still have a 9 year old CRT monitor connected to another pc and if and when it FAILS, I will send it to the curb on trash-day!!! 12fixlouie
Feb 10, 2010 | AOpen A75PF Monitor
Monitor displays verticle coloured lines when turned on
As i understood the explanation you have a problem with the Video card not the LG Monitor.
Jun 19, 2009 | LG Flatron W2242P-SF 22" Monitor
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
No clear picture just wavy lines and error message
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Nov 26, 2007 | IBM 9516 Monitor
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
HP Compaq FS7600 17" CRT Monitor Logo
70 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
