Question about Haier Refrigerators
Inside Not Cooling and Outside is Hot
Even on a high setting the fridge is not sufficiently cooling and the sides and back of the fridge are hot to touch. The black boiler-type object on the back is VERY hot.
    Problem Solver:
  • 19 Answers
Possibly could ned a new comprossor for the fridge.
Posted on Apr 22, 2009
The top of my avanti mini refrigerator is hot
The return section of the gas cooling circuit is hot. Goes out cold comes back hot, so if that area has return lines behind it nothing wrong with the outside of a fridge being hot. Some fridges even have heaters built in around the doors and openings to prevent freezing up.
Jul 10, 2013 | Avanti 322Y Compact Refrigerator
We had to move our Kenmore 18 fridge to install new flooring. When we hooked it back up, we noticed the 3 sides of fridge (freezer sides & top) were hot to the touch. We have a Kenmore18 with an...
its understandable that you fear the unit catching fire but in that the fridge must get hot in order to work. as the heat creates the cold but! in this case i would say your cooling fan placed at the rear next to the compressor has either stopped working or is in need of its blades being cleaned much like a cooling fan in the home when the blades get covered in silt it stops pushing as much cool air around its blades as per clean ones. so make sure the cooling fan turning on and give the fridge a good clean on the outside around the motor area. most importantly dont worry about fire the unit has many built in safety devices before that happens.
best of luck to you
please take the time to rank this repair
merry christmas
Dec 07, 2010 | Kenmore Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
Side by side fridge #ED5FGHXKQ03 is getting warm and sometimes even hot, on the outside around doors and neither sides are cooling and freezing properly.
make sure your condenser coil is clean.then pull refrig out,remove cardboard panel and check for condenser fan motor opperation.if motor is stuck, then replace it. be careful it could be very hot.
Jul 14, 2009 | Refrigerators
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Fridge not cooling
If you look in the outside compartment do you see a yellowish powder? If you do, or if you smell amonia probably the cooling unit has leaked the coolant. It does not help to add coolant, it will just leak out again quickly. You will need a new fridge or to have the cooling unit replaced. If that is the problem, Dometic has a recall on some models for leaks and will pay for a new cooling unit.
Jun 12, 2008 | Dometic Rooftop RV Air Conditioner
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
153 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
