Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Fuzzy pictures Sometimes the camera takes great shots, a lot of the time I get very fuzzy pictures. Do I have the settings wrong. I definitely bought more camera then I need, but too late now!
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
SOURCE:
My sony cyber shot dsc t70 just hasn't been taking great pictures. They're ALL ALWAYS fuzzy. I think it's because I've been fiddling with the settings. Can you tell me how to restore the settings or give...
I'm having the same problem! Its been recommended on a number of websites to restore the factory settings and that might do the trick. You need to go to home, settings, main settings and select initialize to restore what the camera came with - that what I'm going to try anyway! Good luck!
Dec 28, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Battery drainage
20 to 30 shots on "fresh" batteries! Do you use the flash on all shots. That really drains them. I would try to set the camera to "factory default settings" in case you changed something that is causing a drain. I hope you just bought some bad batteries.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion batteries. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Oct 03, 2009 | Olympus SP-550 UZ Digital Camera
Sony Cyber-shot camera automatic focus not working
Turn camera on...Press [MENU] - [SETUP] scroll down [SETUP ] then select [INITIALISE]
Repeat a few times if it does not clear.
If no joy & if you are in the UK I can help you out.
p.m at [email protected]
Aug 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
All of the pictures taken are very fuzzy no matter what you do
check to see if a flower appears on the screen. If it does then the camera is set to macro and all your pictures except close up will be fuzzy. To switch macro off, move the ring on the front of the camera till the arrow is pointed straight down. I was having the same problem. Wasted a whole day of vacation pictures. That was what fixed my problem and I hope it fixes yours too,
Feb 17, 2009 | Samsung Digimax A503 Digital Camera
Trouble taking night time photos
Please go to camera menu and select Initialize and press OK to RESET camera to factory default settings.
I hope problem will resolve.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Screen looks 'snowy'
Sounds like an electronics problem. Try resetting in the setup window. Remove and replace the battery. If these don't work, definitely take it back to the supplier for warrantee repair. Any problems with that, go straight to Consumer Affairs.
Jun 02, 2008 | Casio Exilim EX-S500 Digital Camera
Samsung s1050 says file error
Are you able to transfer the images to the computer? It looks like a memory stick problem.. If your camera has internal memory then pull out the memory stick and save images to internal memory.. If the pictures are alright then you have to replace the memory card.. Do not buy them on ebay. 60% of the times you get fake stuff over there..
Mar 26, 2008 | Cameras
Fuzzy view and fuzzy pictures
I posted on Nov. 25th that I was having the same problem and would be contacting Casio to report the issue. Well did and want to update all of you on the results. I have great news on the blur/fuzzy issue for the EX-Z70 Casio. I called the Casio help line 800-706-2534 and explained the problems I was having with the camera - and mentiond that I believed this to be a manufacturer's defect as I found postings on the internet from other owners of the same camera which were bought around the same time I made my purchase. The rep was very helpful. She instructed me to write exactly what I told her in a letter and mail the camera to the address she provided. If I had my receipt I should include a copy of it - which I did. I mailed the camera requesting repair or replacement on Nov. 26, 2007 and received my camera back today Dec 6, 2007. That's only ten days - Repaired!! The repair report indicates the lens assembly and lens ring were replaced - and a new battery was incuded in the box. The packing slip indicates Defect Code #11. So this IS a camera defect and they were absolutely GREAT about repairing it ASAP and supplying me with a new battery too. Call Casio today and you will have your camera back by Christmas. Have a Merry Christmas - and take lots of pics! Debra - OnPeaHill!
Nov 02, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Fuzzy pictures from my Panasonic DMC-FZ5
Fuzzie picture -meaning out of focus? Check that you have not got 1- macro setting on [setting symbol looks like a tiny plant] or that you have a low light setting which menas it is taking long exposures. Aslso the Auto foxus may not be function as it should - one possibility is that the way you hold the camera covers the 'window' make sure your fingers are aware from any of the front top panel 'windows' When you depress the shutter part way down- does the lens 'motor' to focus Or indeed are you doing part way or are snapping off shot and giving the camera time to focus? Lots of thing for you to check out, before we start getting worried. The difficult ones are if the camera has taken a knock and the lens mount has become dislodged But do all the check first and do consult the manual
Jun 14, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Flash problem
The CCD element has been a great problem in this camera along with a faulty iris in the lens. I would return the camera to the Sony facility in Laredo, TX and let them know the exact symptom you are having. I see many of these cameras being repaired as a "courtesy" because of the widespread problem. Good Luck to you! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
48 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
