Question about LG RUMOR Cellular Phone
My phone says usb connected and it's not connected to anything.
It doesn't work because it says it's connected usb.
  • 83 Answers
Problem with software or internal. turn off phone and take battery out for about a minute. then put back together and turn on. if still acts up. contact ur phone company.
Posted on Apr 22, 2009
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
I have a fake Iphone model A1241 g4gb sw:BYT.A608W.04_A1.1.1 HW:HAOCHENG35_09A_HW i would like to enter engineering mode to set volume because when someone calls me doesn't hear anything. it...
It looks like your loud speaker is burnt off/set to off or anything problematic related to your loud speaker. I'd suggest you to get it repaired by a skilled personnel
Jun 20, 2017 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Computer can not learn my gb 230 when it's connected to him what can i do?
I am going to assume you are using a Windows based PC.
Now I have never come across this problem before but this should help connect more or less anything to a computer.
Switch off your phone and make sure your computer is turned on, then turn your phone back on. Connect your phone to your PC and there should be a message that appears on your mobile phone asking to go into mass storage mode, you want to select yes.
If this doesn't work then you can try other USB ports on your computer or you can open your connection wizard and go through the USB option this should make your computer cycle through all your ports until it sees something.
I hope this helps.
May 25, 2011 | Cell Phones
Hy my problem is that whenever I connect my External Hdd in the computer,It doesn't show anything.The device is working beacause it's light flashes when i connect it.When I buyed it it worked.I...
Hi ludovicungur,
If your device is blinking fast then it means the problem could be that your are using an incorrect mode of connection for e.g. a USB extension cord , or a USB hub to connect your external HDD.
I would suggests you to remove any external cable or USB hub and then connect the hdd directly to the port on *********** board ,if possible try changing ports and it should work.
Hope this helps ..:)
May 10, 2011 | Office Equipment & Supplies
My new samsung Galaxy Ace GT-S5830 will not connect to my computer so i cant Put anything on the phone or taking anything off.
You need the proper drivers to enable your phone on your computer -
http://downloadcenter.samsung.com/content/SW/201102/20110201141300773/Kies_2.0.0.11014_49_2.exe
If this still doesn't work, Check your cable, as it's probably faulty.
On some phones there is an option for "USB mode" or "Sync with PC" - check that as well.
May 09, 2011 | Samsung Lands Phones
Pc screen goes black when iphone connected with itunes running
Hello can you tell me if your iPhone is a 2G or 3G and are you plugging it into a USB 2.0 port?
if it's a 1.0 usb port that could be your problem.
the 3G doesn;t like anything but 2.0 usb and won't work.
the 2G is a little more forgiving.
also, is your phone pwn'd / unlocked
you may need to restore your iPhone and reunlock it.
I can help with that also.
if you wanna hook up on msn or yahoo let me know i will walk ya through it
May 31, 2009 | Apple iPhone Smartphone
My Mobile has a Powering problem and it doesn`t work because it was connected to my PC via USB and disconnected suddenly
contact nokia or a local phone shop to find out where to get it repaired.
www.nokia.com
You can try removeing the battery for 30minutes and trying again.
Jul 26, 2008 | Nokia N73 Cellular Phone
Phone is dead
to turn off the phone just remove the battery and try.. after this if it doesn work out install the phone software again with the usb.
May 04, 2008 | Sony Ericsson W550i Cellular Phone
LG RUMOR Cellular Phone Logo
594 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
