Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
Subzero 550, freezer drawer on bottom: Ice film on back wall of refrigerator (up to about seven inches above vegetable bins). Cold at bottom of fridge, warm near top. (Back wall cold to touch at bottom, not cold to touch at top.) Fridge door gaskets not warm, nor is the frame, except at the bottom above the freezer. Compressor, freon, fan? Which one? all or none of the above? It's possible that the fridge was left open (lots of kids, warm day)--any way that could be the culprit? Thanks for your expertise!
  • 8 more comments
  • Anonymous Jan 06, 2009
    continious ice build up behind the vegetable drawer on a month basis. I need to chop out every month, sub zero 650
  • eggfresh Jan 20, 2009
    21  EC  Flashing Service code and ice build up in back of refrigerator.
  • Anonymous Mar 12, 2014
    Left door open for about 6 hours and now fridge not getting cold but freezer is freezing. Left the fridge door open.
  • Anonymous Mar 14, 2014
    I have an Electrolux French door IQ refrigerator, freezer on bottom. The refrigerator half is staying to warm once in a while it goes back to cold temperature but it doesn't last very long and then it goes back to 50-55 Wondering if it could be the computer board or just the fan issue and how I might be able to tell?
  • Anonymous Mar 19, 2014
    my fridge rs250s lemair fridge only is icing up on the back wall and not keep things cold why?
    my fridge has a lot of ice in the freezer to the point that the fan hits it when it turns! And plugs the vent to the bottom part! Can you tell me how to fix this? thank you
  • Anonymous Mar 23, 2014
    mod#ed22pexht00 whirlpool
  • Anonymous Mar 25, 2014
    Freezer drawer will not close
  • Anonymous Mar 30, 2014
    Our Haier fridge is like cycling?? It will cool then it feels warm. Why is this?
  • Anonymous Mar 31, 2014
    Fridge side has stayed cold, freezer has completely defrosted.
  • 67 Answers
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Posted on Sep 24, 2007
Subzero freezer not freezing
this subzero freezer compartment did not free, but stayed cool. The problem was that defrost limit switch went bad, so when it was going to defrost cycle heater never came on, so it builded up snow and ice on evaporator coils and air stopped circulate. I replaced that little thermostat, and melted down ice.
Jul 11, 2014 | Sub-Zero Bottom Freezer Refrigerator
Subzero 550 bottom freezer
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down
the rear wall of fresh food compartment until it reaches the crisper drawers. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is nother way to make this look more simple in clip above. echnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=>
Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
May 13, 2013 | APW Wyott SubZero Refrigerator Freezer...
Subzero 550 bottom feezer will not drain
This only sounds like a blockage in the condensate collection pan below each evaporator. Your model has a evaporator below each the freezer and the fresh food compartment. You will need to unplug the refrigerator ansd remove the panels covering these evaporators in order to see these condensate collection trays. Go to page 81 in the=> Sub-Zero_Built-in_500_Series_Refrigerator_Service_Manual.pdf You are going to have to remove these panels to understand what to look for when it comes to condensate collector pans with the drain in the middle bottom of each. Ask questions if you want I am here to help, Thanks Sea Breeze
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more simple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the
Breeze
I have a Model 550 SubZero Refrigerator. I have ice build up on the lowere left rear interior wall just above the criper drawers. Can you advise on cause and fix?
Check your door and door gasket. Make sure it has a tight seal. The ice is from air and moisture getting in on the left side.
I hope this helps. Please leave feedback.
Thank you.
Aug 24, 2010 | Sub-Zero Refrigerators
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water is not draining down the drain tube in the main compartment of the subzero 550 refrigerator
clean drain line . force hot water down the drain as the get algi and stuff in them . if problem happens again then use a drain heater kit ( subzero ahd one for this model ) this will prevent ice over .. **** hope this will help ..
Dec 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
ICE IS FORMONG ON THE BACK WALL OF A SIDE BY SIDE SUB ZERO REFIGERATOR.
This is typically a problem with the sealed system (refrigerant leak). Usually a circular patch of ice or water driplets half way down on the back wall. The solution involves replacing the evaporator coil. Subzero will give partial warranty up to 12 years.Full warranty for 5.A subzero authorized company is recomended.
Sep 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
946 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
