Want reset the remote want open the gauage door
  • 32,281 Answers
Your remote might just need the battery replaced.
Posted on Apr 22, 2009
Help truck was stolen, I used remote control to "teach" truck how to open door... I reset door opener and relearned the remote..my question is do the remote have a new entry code when I learn, or remote is...
Ounce you reset ALL code of the garage door opener (engine hook up to the ceiling of the garage that open up the door), ounce you press the reset button on the unit, it disable all transmitter (portable or the one install in your vehicle). Your garage door opener has a receiver in it and your all units that you press on to open the door are the transmitter, so by pressing the reset button on the door opener, you erase all codes of all the transmitter that where programmed to open-up that door.
So if you teach your vehicle using a portable unit and you now reprogram your new vehicle with the SAME portable transmitter, then yes who ever has your stolen vehicle can come back with your stolen vehicle to your house and open up your garage door since you re-programmed the door opener using the SAME transmitter same code sent to the unite to active it).
Buy a new transmitter to re-programmed your new vehicle
Jul 13, 2014 | Building Materials
My remote is opening both my door and my neighbor's door. I think we accidently swithched them and once reporgrammed, mine opens both doors. How can I re-program it to open only my door?
one or the other remote has an error so when you set up your remote make sure neighbor is not home ... I had this problem when my neighbor was home and I reset my remote and keypad ... later I noticed my neighbors door either opened or closed with mine I called customer support and found the neighbors sensor emitted constantly and reset to mine. ... soo Reset you remote and keypad if you have one when you neighbor is away!!! :)
Sep 29, 2009 | Televison & Video
I have a sears garage door opener with two openers and one code remote (mounted outside of the garage). I had to replace a battery in one of the openers and when I went to reset it I accidentally reset all...
Keep the remote that works with the keypad and replace the other remote with one of the same model. This is a common problem and the only cure is replacement.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO 1/2 HP - Remotes not working after storm
sounds like it blew the reciever crystal buy another and return the motor thats fried 4 refund
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
unplug the power of your door opener for a few minutes and plug it back in. Try the remote control that you have and see if it opens the door. If it doesn't open the door, reprogram [learn] the remote control you have and that is it. The other remote will be useless ... and you just proved it to yourself!
Sep 13, 2008 | Kitchen Appliances - Others
Remote and Keypads open neighbors door
Hold down learn button for 8 seconds. This clears the memory for all remotes. Then reprogam your remotes
Oct 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
