Question about Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
No game connection
Windows XP media center ed. 2005. just bought and loaded the Logitech rumblepad 2 for my kids. the setup and test seems to go OK. All the functions work in the test mode. When we load a game (Age of Empires II, or Call of Duty) the mouse works as usual but no thing works via the Rumblepad. Ive tried restart, and updating the activeX (or something X) Can't find a game setting that would enable, dis-enable, a game controller. I'm a PC dummy so don't assume I can follow tech jargon--if there is something simple I could have done wrong, I probably did.
  • 68 Answers
Re: no game connection
What i would suggest for this problem is for you to use add remove programs. Remove the firmware or software for your rumble pad. Then use your favorite search engine and look for a a registry repair program and download it ( this is just incase that during your install it might of changed the registry that it would not reconize your rumble pad) once you have run this program then install the rumble pad according to what the manufacture has printed. Follow each step exactly as they printed. This is critical because each add on to a computer requires a specific order for the install to be complete and for the registry to enable it. After you are done installing it. Go to your system settings and into device manager. There you will find a list of devices avaliable on your computer. look for your product usually listed under USB. Once you find it click on it and go through the menu to see if this hardware has been enabled and there is no problems. If there is a problem you will see "!" next to the problem area.
Posted on Sep 23, 2007
0 characters
3 Points
Want to use logitech gamepad with fallout 3
You will need a setup for that. I can try to make the setup and reply you within the next few days with the download link. I ll need some time.
Mar 23, 2010 | Logitech Rumblepad 2 Vibration Feedback...
Logitech Profiler detection issue.
plz contact with microsoft support for the problem...
Feb 07, 2010 | Logitech Rumblepad 2 Game Pad
Logitech Cordless Rumblepad 2
You need to set up profiles to use this gamepad. I ve made several profiles. Most downloaded are Call of duty MW 1 & 2 and NFS Shift setups. Download them here if you need them:
COD 4 MW and COD 6 MW 2
NFS Shift
Oct 10, 2009 | Logitech Cordless Rumblepad 2 Vibration...
I recently downloaded "Fallout 3" using "Steam" and bought the Saitek "P380 DUAL ANALOG" gamepad to play it with. A message appeared on my screen saying that the gamepad was installed and ready to use but...
XBOX360 Controller Emulator
It helps. I got my saitek ps2700 to work with fallout3 with it. Yust download and install using instructions in readme.txt.
Jan 29, 2009 | Logitech Rumblepad 2 Vibration Feedback...
Gamepad use
The program that comes with the rumblepad allows you to map actual keyboard functions to each button.
Mar 07, 2008 | Logitech Cordless Rumblepad 2 Vibration...
Logitech cordless Rumblepad 2
I purchased the Rumble-pad 2 controller but trying to get it to work with my Splinter Cell Pan... game seems impossible can you help?
Jan 01, 2008 | Logitech WingMan Cordless Rumblepad Game...
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Dec 30, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Logitech  Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758) Logo
444 people viewed this question
Top Logitech PC Game Controllers Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Logitech PC Game Controller Expert? Answer questions, earn points and help others
