Brother MFC 8840D All-In-One Laser Printer Logo
Posted on Apr 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Brother MFC8440 Wont photo copy very well, the copy comes out light and most of the things are missed, not sure how to fix? Is it the toner or something else?
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Apr 22, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
16968
Points
141
Replaced the toner and you probably need to repalce the drum also
Brother hl2270dw toner light stays on
Have you tried resetting it? I can't remember all the steps, I see some of the other comments have them but just to be sure you didn't miss anything I suggest you download the manual and go step-by-step. You can find one here - Brother HL-2270DW manual
Brother mfc 7440n printer/fax running very slow
Depending on how many copies you have it might be time for a new drum unit. Also, you can change the settings for the resolution for copies in the main menu. Check Menu--Copy--Quality and make sure it is not set on Photo. This would definitely **** up toner as it would print at the highest resolution rather than the default resolution.
Brother MFC8440 - Left Hinge Assembly broken
Brother will not sell to end users, contact a Brother Dealer in your area.
Prints beautifully from a scanned copy, but light when copying
Check your copy option,constrast to high and quility to Auto.
after that should be fine.
1helpful
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Poor quality of copies
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Brother 6800
Clean your laser window on the bottom of the interior of the machine.
The only other common options can be are the contacts of the drum. They can become bent and not give good contact. Bend them back.
When the laser fails it will also become light but it will stay light once it is going.
Check the stupid things - once I had a customer change the toner and not take the tapes off. Had similar symtoms to your problem.
Toner
Likely thing is that you have a faulty toner cartridge return it to the store and ask for a replacement in exchange as yours is faulty. IF this does not cure the fault then maybe the drum unit causing the fault and this may need replacing.
Thanks J
2answers
My MFC8440 Cover Left Hinge Brocken
Very common part any brother dealer can get it. Ring brother to find closest dealer about 20 bucks
2answers
Toner yield doesn't meet standard copies
THIS PROBLEM HAPPEND WHEN THE DEVOLOPER IS WEAK. TRY TO CHANGE DEVOLOPER ADJUST THE TONER SENSOR OUTPUT BY PROGRAM 05 -0 IF NOT TRY TO ADJUST TONER CONSUMPTION PROG 05-92 IF NO ACTION CHEK ANEARBY TOSHIBA AGENT TO CHECK IS ANY THING WRONG WITH THE MAIN CONTROLLER BOARED THANK YOU
Norman Weimar
Norman Weimar
k24674
