I am getting this double line down the paper when I scan. No problem with printer, just scanning feature. HELP ! Thank you!
4 Other Users Have The Same Problem
Comment by Red Cedar, posted on May 15, 2008
I have 3 vertical black lines running the length of the document after copying on my HP V40xi all in one. I cleaned it and it took care of some lines but these 3 still are there.
Comment by Guest, posted on Apr 07, 2008
HL-1440 Laser printer prints double lines all the time.
Please help.
Comment by congaboy, posted on Apr 01, 2008
A yellow line appears on the right side of all of my scanned documents. It just started doing this a few days ago.
Comment by schotte, posted on Mar 07, 2008
I have another problem the printer works but scanner does not I keep getting the message the the scanner driver can not be installed, does anybody else have this problem I am useing Vista Home.
Regards Neil
Was this solution helpful? Show your Appreciation by rating it:
Cops is correct if you lift up ANY all in one machines, you will notice that there is a 1inch glass and then there is the main glass. When printing, scanning or faxing from the FEEDER it makes the copies from that 1inch glass, if there is a DOT on that part of the glass it comes out as a line. Why? because the paper is moving that dot then becomes a streak on the paper. To test if it is a dot try doing it from the main glass, there should be no lines ( the paper is not moving!!!!).
sometimes it is very hard to see anything on the 1inch glass, but it's there, the background is black and it may be a black ink or pencil dot. To try and localize it, take the copy with the line and align it with the 1inch glass, look carefully and clean with alcool.
when removing it obviously dont use a sharp object as this will scratch the glass and futher more impare the picture
Post a New problem for HP OfficeJet 7310 All-In-One InkJet
Email this problem
Can you Help with these Printers problems?
two-sided orientation of text
printing yahoo email
7310xi will not fax in/out.
HP Officejet 7310 All-in-One
