Question about GE Dishwashers
Water leak leaking water under the unit... it is 25 years old
25 yrs old I suggest replacement..than spend maney
Posted on Apr 22, 2009
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Water heater is leaking from the bottom of unit. it is a 20 year old 119 gal mod# dve120 916 what would you recommend we do with these heaters
Any water heater that is leaking from the bottom needs replacement. A 20 year old water heater has given you great service, you are very fortunate.
Jan 06, 2011 | Water Heaters
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
Airtemp - 25 yrs old. Water leaks from bottom of
Is the unit level? it's pulling moisture out of the air and not draining threw the drain hole normally it's cause by the unit not being leveled.
Aug 10, 2009 | Heating & Cooling
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Water periodically leaking from under refrigerator
we had this problem. Repair guy took all contents from freezer, defrosted it. There is a hole near the bottom in the back. It is for overflow. It was clogged or too full. Make sure the hole is cleaned out. Works fine now.
May 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Dishwashers Logo
46 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
