Question about Ellington ROC52ALUM3LKRCR2 Rocket Ceiling Fan
Fan is spinning the wrong way
The fan is making the room hotter and i found out its because its spinning the wrong way and i need to know how to reverse it. plus my remote doesnt work
    President:
  • 1,489 Answers
Have you checked to see if there is a switch on the fan housing? Usually this is how you select the direction the fan is spinning. If it's spinning clockwise as you look up at it, it's blowing air up. If it's spinning counter-clockwise it's blowing air down.
The remote not working could be:
- it needs resetting/synchronizing with the receiver, or
- the battery (ies) is dead, or
- the remote (transmitter) or the receiver is bad, or
- the receiver has loose connections.
Check the owner's manual -- do you have one?
Posted on Apr 22, 2009
Toyota camry 07. The AC unit was replaced after it was in an accident. The Ac blow cold air when it's below 80F outside. When it's hotter than that, it only blows warm air. I took it to different auto shop...
did the check or change the expension valve,and also check the dryer and may be it need oil in the compressor when it has load it may run hot,another thing to check make sure the car cooling fans work properly
May 03, 2014 | Cars & Trucks
Tip
Keeping your whole home cool with central air.
Sometimes it is difficult to keep your home cool in the hot summer months. Also, some areas of your home may still be hot where other areas are too cool. Try this method to keep your home cool evenly throughout. Before you get started make sure your furnace filter is new. This will allow for maximum air flow.
If your living space is a single floor plan:
  1. Turn the air conditioning on
  2. Switch the furnace fan from auto to on.
  3. Measure the temperature in each room.
  4. Close the vents by about half in the cooler rooms
  5. This will force more cool air into the warmer rooms.
  6. Keep adjusting the vents until all the rooms have the same temp.
If your living space is on more than one level:
  1. Turn on the air conditioning.
  3. On the lowest level of the house close half of the vents that are the closest to the stairs.
  4. This will force more cool air to the top floor where it is usually hotter.
  5. Cool air will sink from the upper floors which will keep the area near the stairs cool.
  6. Measure the temperature in all the rooms.
  7. Keep adjusting the vents until you have a nice even temperature throughout the house.
I found that leaving the furnace fan on all the time will keep your home evenly cool and comfortable. You may have to replace your furnace filter once a month due to the increased air flow. It will be well worth it in a cooler, more comfortable, and more energy efficient home.
Take Care,
Eric
on Aug 09, 2010 | Heating & Cooling
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
Honeywell tower fan
call the HVAC man. LOL
it's not a cooler or A/C, that the sales hype states !
its JUST A FAN, and fans only circulates air.
or if you are inshorts only, it help with wind chill and sweat evaporation,
I have a huge fan in my garage. just for that, and fume , reduction.
you set 68F and the temp goes UP, ?
but what goes up , do you mean the actually measured temperature? state what told you it went UP?
if yes, (actual temp) sure it can, if there is hotter air , say up high?
then you mixed in hot air with cooler air down low, and guess what
it does get hotter. (physics 101?)
what do you want to go down. ?
the actual air temperature?
or do you think you bought a real air conditioner.
to make real tempeture go down
buy a real air-conditioner, not a fan.
Sep 28, 2013 | Honeywell Hwlhy108 Quietset 8-speed Whole...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
99 chevy s-10 2.2l the temperature is slowly increasing
if you have electric fans, make sure they are working and that there is sufficient coolant in the overflow tank and radiator. If you have a manual fan clutch, try spinning the fan with the engine off, It spins freely or goes around more than once with just a quick push, your fan clutch is bad and needs to be replaced. and it is a fan clutch...not a clutch fan...as people sometimes call it.
Aug 02, 2012 | 1999 Chevrolet S-10 Pickup
New thermostat good temp at all speeds get to 65 runs hotter 70 hotter 75 even hotter wonder if fan temp switch is going bad fans only come on for 10 or 15 seconds?
high speed overheating are a good indication. something is wrong with radiator. check coolant level, make sure the fans are working, and check radiator for broken fins or dirt and debris in radiator fins. if air is not going through radiator, it will over heat. if all is fine. replace radiator cap to see if this fixes problem. but check radiator fins first for debris.
Jan 30, 2011 | 1994 Toyota Camry
Need a fix for a loud processor fan!
Take a can of compressed-air, and give a "blow-job" to the cooling-fan, to remove all the dust, which is acting as "insulation", causing the computer to run "hotter", and causing the motherboard to spin the fan faster, to try to make the computer run "cooler".
Or, enter BIOS SETUP, and check the fan-speed settings.
If the fan-speed is set to "100% for 100% of the time",
try a lower setting (which will be quieter).
Oct 23, 2010 | Gateway 560GE PC Desktop
What does turbo swirl mean? I have a three season room with a shed ceiling. So I want to know if the turbo swirl will produce enough air movement for a 12 x 12 room.
Turbo swirl does actually mean anything it's just a description given by the manufacturer to make the fan sound good and appeal to your senses by making you think it works good. You need to look at the specs on the box and see if it has a recommended square footage of space for the usage. It could also give you something more specific regarding air flow but it may not even have this information.In my opinion I think this fan will be fine for only a 12 by 12 room.
Aug 23, 2010 | Westinghouse 78144 Turbo Swirl™ Brushed...
My side by side was not very cold.
you will have to replace the condensor fan motor
Jul 01, 2009 | Whirlpool GC5SHEXNS Side by Side...
Ellington ROC52ALUM3LKRCR2 Rocket Ceiling Fan Logo
575 people viewed this question
Top Ellington Dryers Experts
john h
Bill Boyd
Are you an Ellington Dryer Expert? Answer questions, earn points and help others
