Tv won't stay on
Tv shut off when I was watching it. Tried to turn back on and it wouldn't turn. Unplugged it and let it set for about 6 hours. It is an RCA model# P52721LV
  • 1 more comment
  • Armmaggeddon Jan 07, 2008
    I Bought A RCA Model# HD52W66 Less Than 2 Years Ago And I Am Experiencing The Same Problems
  • hermeljamar Apr 26, 2008
    I have an RCA HD52W66 and I am experiencing the same problem. I have had the T.V for less than 2 years. What options do I have?
  • Anonymous Sep 27, 2008
    I have the exact same problem.  I was watching it and it just turned off and I can not get it to work again.  Samsung HCP4252W 42" rear projection hdtv
I am experiencing the same problem and have done a little research and it seems it can be multiple problems. The main ones I have found are the need for a replacement amp fuse, a bad diode, a problem with the power unit. When it looks like a problem with the powering unit you may have a soldering problem on the internal boards of the television. From these errors it sounds like a relatively cheaper fix less than 150.00
Posted on Feb 24, 2008
SOURCE:
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
New 42inch plasma turned off while watching, can't turn on
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
May 31, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Samsung 54" Projection TV (PCN5425R)
sears does inhome service, if you do try to fix it, there is usually a board mounted to the back of the tubes (above the others), if it has this convergence board, try unplugging the red connector with the blue wire and turning set back on, if it powers with a 3d looking picture, you have a bad convergence module. Other than that you may want to call a repairman.
Jul 08, 2007 | Samsung PCN5425R 54" Rear Projection...
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Ekse
