Question about HP ScanJet 2300C Flatbed Scanner
The scan has many lines on the image
The output in my monitor has lines in tne image
  • HP Master
  • 3,866 Answers
Reinstall the scan TWAIN driver good luck
Posted on Apr 22, 2009
How to solve acer ac 512 monitar haricantal problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 09, 2014 | Acer AC 501 15" CRT Monitor
32 monitor receiver
The vertical scan output stage to this set has the fault. Check and replace damaged component/s at its vertical scan output circuit section. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 06, 2014 | Sylvania 6427TE 27" TV
How do i get the progressive scan off
Once the setting for progressive scan output is entered, an image will only be visible on a progressive scan compatible TV or monitor.
If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that 'dISC' is displayed on the display window.
2) Press STOP (on front of unit) and hold it for more than five seconds before releasing it (10 seconds is better).
The video output should be restored to the standard default setting (interlace) and a picture will once again be visible on a conventional analogue TV or monitor.
Hopefully that solves your problem.
Apr 02, 2011 | Zenith XBV442 DVD Player/VCR
The image is getting smaller
If in the horizontal direction your line output stage requires attention, new line output transistor/ capacitors etc. If in both dimensions probably a power supply fault.
Mar 07, 2011 | Dell E773C 17" CRT Monitor
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
HP 5470c scanner leaves lines on the scanned
This is often caused by dirt or dust on the imaging head. This requires taking the unit apart in a CLEAN area and wiping off the head with lens cleaner and a microfiber lens cloth.
Apr 16, 2010 | HP Scanjet 5400c Flatbed Scanner
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
HP ScanJet 2300C Flatbed Scanner Logo
233 people viewed this question
Seeker5211
Seeker5211
