Question about Samsung Q1 Tablet PC
Samsung Q1 Mouse Pointer / Stylus don't match up
The mouse pointer on the screen does not match up with the stylus. Particularly once closer to the edge of the screen, the mouse doesn't go ar far as the pointer do you can't select items in the task tray of use the close "X" in the far upper right corner. Anything on the edge of the screen is unselectable because the mouse pointer just won't go there? Can anyone determine if this is an error/bug, or if I just need to adjust this somehow?
Samsung Q1 - Pent. M - 1GHZ - 1GB.
4 Suggested Answers
mansnes
  • 50 Answers
SOURCE: Touch Screen won't work on Windows
Is it running Windows TabletPC operating system? This version of the OS includes support for the touch screen.
There is also a known Microsoft problem that this might be related to. You can check out this link for more information: http://support.microsoft.com/kb/914444/en-us
BTW, Microsoft does not charge for calling to get a hotfix like the one listed in this article.
Posted on Feb 11, 2008
ginko
  • 19396 Answers
SOURCE: samsung q1 black screen
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Posted on May 05, 2009
SOURCE: Samsung Ulta Q1
There are two Youngshin-t AWM ribbon cables that wrap around at that point of the unit. Have you or someone taken the unit apart to upgrade the RAM or anything like that? I bought a used Q1 Ultra and previous owner was an idiot and had litterally broken several leads in the 10cm ribbon cable and also pits in the longer ribbon cable. There is a video online with a gentleman who does a ram upgrade, you can watch this to learn how to safely open the Q1 Ultra and check the stylus housing area for a short.
I'm not sure what Chipworm is talking about because the housing for the stylus does not contain any type of sensors that I am aware of. I've taken the Q1 Ultra apart down to individual components.
Posted on May 13, 2009
Just recently my Nextbook screen went Black but i can still see The mouse pointer and i can still use The volume. I tired turning it of bit it does not want to power down. How can i fix it?
I don't believe it is something software dependente: guess sceen or screen related circuit is damaged and you should change it but. Is it possible? I don't know. You should evaluate it at some computer repair shop.
May 06, 2015 | Nextbook Tablets & eReaders
When I use my samsung tablet I am getting lines on the screen as if I am writing with a pen I am not using a stylus , I am using my fingers this has juststarted happening in the last few days
Go into the Settings app. Near the bottom you will see Developer Options. Scroll down through the developer options to see if "Show Touches" or "Pointer Location" are checked. If they are, uncheck them.
Jan 02, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
How do I take a screenshot?
Adjust the window size to the size you want to capture. Hit the Alt key and the Prt Sc (Alt+Print Screen) at the same time. Open the application you want the screenshot in and use the paste command (Ctrl+V).
Sep 09, 2012 | VanGoddy ZTE Optik from Sprint Tablet...
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
When I click the mouse pointer it doesn't work I have no choice but to use the right mouse buttons to make selections. How do I fix this issue?
Usually this problem can be easily solved by accessing and changing your mouse settings. On your PC desktop, click "start", then click "control panel", then click "mouse", then on the "buttons" tab you'll see an option that says, "button configuration". That button needs to be adjusted according to which side of the mouse you'd like the pointer to work from. Once you set the side you'd like, make sure you click, "OK" to seal the deal!
Hope this helps.
Sincerely, CBR2009
Jul 16, 2009 | Gateway M280E
Feb 11, 2008 | Samsung Q1 Tablet PC
Samsung Ulta Q1
stylus is controlled by the softwares , sensors are working fine in the pc . software problem is mpre likely then a hardware , try re-installing the OS , if it doesnt work the only you refer the company people (the manufacturers)
Nov 06, 2007 | Samsung Q1 Tablet PC
Erratic mouse/pointer behavior
I ended up calling IBM support (after many calls to them) and since the Tablet was still under warranty I sent it out for repair and they ended up replacing the planar card. Tablet was returned and I have had no further issues with the mouse.
Oct 16, 2007 | IBM ThinkPad X41 Tablet PC
Samsung Q1 Tablet PC Logo
228 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
