Stat Tracker advertisement has come up on my fantasy baseball where my players stats usually are and I am can't get rid of it.
  • 460 Answers
Is because your Pop Up is On
How to configure the Pop-up Blocker for zones that are considered safe. loadTOCNode(2, 'moreinformation'); Because the Trusted sites and Local intranet Web content zones are considered safe, they never have their pop-up windows blocked. To configure the Pop-up Blocker for these zones, follow these steps:
  1. Click Start, point to All Programs, and then click Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. Click the Security tab, and in the Select a Web content zone to specify its security settings box, click Local intranet.
  4. Click Custom Level, and under Use Pop-up Blocker click Enable to turn on the Pop-up Blocker, or click Disable to turn off the Pop-up Blocker.
  5. Click OK two times.
  6. Repeat steps 1 through 2.
  7. Click the Security tab, and in the Select a Web content zone to specify its security settings. box, click Trusted sites.
  8. Click Custom Level, and under Use Pop-up Blocker click Enable to turn on the Pop-up Blocker, or click Disable to turn off the Pop-up Blocker.
  9. Click OK two times.
For more information about the Internet Explorer Information Bar in Windows XP SP2, click the following article number to view the article in the Microsoft Knowledge Base:
843017 (http://support.microsoft.com/kb/843017/ ) Description of the Internet Explorer Information Bar in Windows XP Service Pack 2 Your rating is very important to me Was this helpful?
Posted on May 22, 2009
How do I get rid of stat on my calculator screen
STAT is the mode where you can do all your statistics functions. To change between Normal and STAT mode you need to press the MODE button (just below ON) and choose 0 for Normal.
May 30, 2014 | Sharp el-531x scientific calculator
How do I get rid of the ERR:DIM MISMATCH message?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jun 08, 2012 | Texas Instruments TI-84 Plus Calculator
How do I get rid of the ERR: INVALID DIM message?
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
When I try and graph on my TI-84, "ERR: INVALID
Dec 09, 2010 | Texas Instruments TI-84 Plus Calculator
How do I get rid of Error: invalid dem
If this isn't the case, please respond to this post specifying what you're trying to do when you get this error.
Oct 14, 2010 | Texas Instruments TI-83 Plus Calculator
Program entitled "Ajax" message "Ajax is not supported"
go to http://www.java.com and make sure that you download the latest version of the Java Software.
Apr 14, 2009 | Computers & Internet
A contractor cut the wires from my Coleman forced air furnace, It was hooked up to a stat that ran my evap cooler and heat. I am trying to put in a new straight heat stat but I can't get the stat to...
Does the new stat have a pin labled (G)? Connect your fan wire (usually green) to that pin, and then call for fan on your therm. Straight heat stat means it has only heat and cool pins, there is no option for fan. If your not getting the fan to come on including heat, make sure you have the white wire and red wire connecting to your new stat.
Dec 06, 2008 | Heating & Cooling
Wont start up
pretty basic stuff. power cord could be abaded . check to be sure power is reaching the stat with a meter. if it is then check to see if its reaching compressor with a meter, obviously the box is hot so sta t should be calling if power arrives at stat but doesn't come out stat is bad. if it gets to compressor but no run then the compressor start components or the compressor itself are bad. stat has a power in lead and a power out lead. if you check volts between terminals and show 120 the stat is open and bad. if it is set to max cold and failing to send run signalit has to be the stat. if you have power to stat and stat shows no voltage terminal to terminal then its closed and power is not getting to compressor, trace wiring and check .if power is getting to compressor the checjk start cap and relay . if they are good then compressor is bad , usually to expensive to replace.
Nov 18, 2008 | Freezers
Freezer defrosts and unfreezes everything. A day or so later it refreezes.
most domestic freezers do not have a defrost control. .90 percent of them freeze and every few years enough ice builds up that you have to unload and manually defrost them. so what is probably happening is the stat is sticking in hte off position and not recognizing the call for cool when the temp gets up. if you catch it off and thawed try tapping the stat gently after the temp is getting way warm. if the box comes on and starts freezing again then the stat is sticking in the off cycle and needs to be replaced. usually under 75 dollars and fairly easy. two wires connect in any order.the stat itself has no in and out requirements. power in and power out when it closes. there may be a ground wire usually green and smaller connector attached to some newer stats. look close and you can see the difference. usually the voltage connections are next to each other and the ground is off to the side or end. stat is usually behind a plastic cover inside the freezer. good luck, disconnect power when you change stat of course.
Nov 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Open Questions:
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
