Says the network is out of range when i'm right next to it
Remember 196.254.x.x mostly we call bad ip address in
fact this is not a bad ip address, The INTERNET ASSIGNED NUMBER AUTHORITY(IANA)
has reserved the private ip address in the range of 169.254.0.0 to
169.254.255.255 for automatic private addressing. So this addresses are not
found on internet. That is the reason we cannot go online with this ip
addresses normally.
TRY FOLLOWING STEPS
Open Connect to a Network by clicking the Start button , and then clicking Connect to.
A list of networks currently available is displayed.
Do one of the following:
If the network that you want to create a profile for is in the list, click it, and then click Connect.
If you save the network after successfully
connecting to it, a profile for the network is stored on your computer.
The next time you open Connect to a Network, the network will be in the
list of available networks, if it is in range of your computer.
profile for is not in the list and you think that it is in range of your
computer, make sure that the wireless network adapter on your computer
is enabled by doing the following:
Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
Right-click the network adapter, and then click Enable.
If the network that you want to create a profile for is not in the list, click Set up a connection or network, click Manually connect to a wireless network, click Next,
and then follow the instructions. If you save the network, a profile
for the network will be created and stored on your computer. To select
specific authentication and security settings, click Change connection settings.
