Question about Nokia N73 Cellular Phone
Problem with incoming call ring alret
When incoming a call my mobile some times rings with ringtons and some times no ring,only light alret.After switched off and switched on mobile ok and ring on incoming call.always this problem.pls solve.
  • 35 Answers
It may change due to your profile or because of your memory card (if u have one).
Posted on Apr 23, 2009
Change ring tone
How to Change the Ring on a Motorola V360
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
May 30, 2011 | HTC Wildfire Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My mobile (model: nokia 1650) restarts when I try to set the ringtone. My phone is now in silent mode and does not ring or vibrate for any incoming calls. Could you please provide a solution for the same....
you want to goto settings in your mobile phone and select restore factory setting, in that type the security code 12345 and press ok .then the problem will be solved
Dec 30, 2010 | Nokia 1650 Cell Phone
Delay in my mobile ringing time.
go to profile settings,,,
select ringing tipe: ringing,,,, not ascending,,,,
hope it will work,,,,,,,,
Jan 14, 2010 | Nokia N73 Cellular Phone
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
Dec 21, 2008 | Lands Phones
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Ringing time
your phone accepts downloaded audios for ringtons, if you want a long ringtone, you may set a whole song to be your ringtone, or perhaps a long ring ring sound.
or if you only want your regular tones to be longer, try to set the ringer to "ASCENDING"
Aug 09, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Nokia 7373 not ringing
hi there you need to go on to your tone settings and see if you got the incoming alert '0ff' because this is one of the main reason why your phone wouldnt ring, also check your on alret for calls and see if you calls switched off. you may also need to go on to your profile and check if you have got it on silent and this is another reason why your phone may not be ringing. hope this helps
Aug 29, 2007 | Nokia 7373 Cellular Phone
Nokia N73 Cellular Phone Logo
183 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
