I need help
My synaps monitor keeps flashing colors what do i do?
  • eeugenio24 May 11, 2010
    Possibly an electronic part/s of your monitor is defective, try to get help from TV / Monitor service repair shop. regards
  • 94 Answers
Goto setting button and reset the setting if not working you need to take to a technician
Posted on Jul 22, 2009
Synaps monitor
Your monitor could have had a power supply failure.
Dec 04, 2013 | Computers & Internet
Driver for Synaps mw9bbk
The flashing power light and very slow display is an indication that the internal power supply board is failing. This is usually caused by bad filter capacitors on the board. You should be able to repair the unit by replacing the bad capacitors.
Sep 25, 2012 | Computers & Internet
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
After couple hours of use the screan will go black and power led will flash. If left unpluged for a while (2-3) hrs and is pluged back in it will work again for a short piored of time. I was guessing that...
Just repaired mine. Had a couple of bad caps on the power board.
For disassembly, on the back the two hinge covers will slide off sideways, exposing 4 screws holding the hinge assembly to the monitor. remove that piece and you can get to all three screws holding the plastic monitor shell together. After those three screws are removed, its just snapped together so use a small screwdriver or blade to pry apart. I started at the button area on the bottom and worked up from there. Good Luck.
May 17, 2010 | Computers & Internet
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Synaps 24'' MB24WKH LCD Monitor no image displayed
Thank you shad193. I've probably solved the problem with my MB24WKH thanks to your experience.
Dec 21, 2009 | Computers & Internet
My synaps monitor screen can only be seen when light is bright on it, think it had sun exposure due to open window
If it's an LCD, there are two light behind the screen. If they burn out, no light to see the screen. Replacement lights cost more then a new monitor these days.
Jul 05, 2009 | Computers & Internet
Bright colors when computer is off
Turn off the monitor when powering off the pc.
Apr 14, 2009 | Computers & Internet
Synaps Monitor Model MT5WBP
i had the same "no input signal",and tried all of the "fixes" i could find without any luck.nothing was helping ,and i kept getting the "no input signal" message.i once had a remote control that would get frozen up ,and the only way to get it working was to :remove the battery's and push-n-hold the buttons down to discharge all memory.and thats how i got my,synaps mt5wbp, to finaly work.here is the fix:while holding the monitor upsidedown{buttons up},remove the power cord.then,push-n-hold the buttons for 10-15 seconds.all of them.you dont need to do all at once but it may help.do them all. my,synaps mt5wbp, has worked fine ever since i did this ,so give it a try.good luck.this worked on other things to.like my frozen TV remote control.
Nov 29, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
