Question about Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2
Ballaster makes a ticking noise,wont fire up
I got a new 600watt solarmax bulb for my grow light( which is a 600watt hps system), it doesnt fire up. all what happens is the ballaster makes a ticking sound for ages. but if i put my old bulb back in, it works straight away.why is this? could someone please help me with this thanks.:)
    Sergeant:
    Champion:
  • 404 Answers
Make sure the light is a hps one
Posted on May 29, 2009
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
400 watt hps grow light just bought it but wont work!
Please review the following information.
https://www.sunlightsupply.com/page/technical-information-guide
Take care note of the discussion of connecting the ballast to the lamp housing and ensuring the ballast is NOT connected to the mains when the lamp housing is connected or disconnected from the ballast.
Also be aware the system will not allow you to turn it off and then immediately turn it back on again. There is a built-in safety feature to ensure the lamp and ballast are not damaged due to loss of utility power. There is a 10-minute delay built into the system in the event utility power is lost..
Nov 01, 2017 | Sunlight Supply 400 Watt Hps Sunsystem I...
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
One of my two hps bulbs is brighter than the other one the bulbs and one of the ballast are new the other ballast is a year old
Hi .. it could be the ballast .. an easy thing to do to troubleshoot this would be to swap the lamps. If the problem follows the lamp. then that is the problem. If the pronblem stays with the fixture, then I would replace the ballast in that fixture.
May 03, 2010 | Sun System 600 Hps Cool Grow Light System...
400 watt grow light
ballast is weak ,or the bulb. i would never by the combo lights /use a hi pressure sodium for both vegative state and flowering.you dont necessarily need a MH..
Jan 03, 2010 | Garden
Ticking noise, not working
2 things are the bulbs good? if yes disassemble the light and remove ballast look at power loads and find equal on at home depot Loews or light store
Jul 14, 2009 | Hydrofarm 2 Ft Green Thumb Grow Light...
Hello...need help.. replaced 600mh bulb then
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
400 watt HPS
The ballast may not be the problem. The problem may be the ignitor (starter). If the fixture humms, then the ballast is most likely working. Ballasts (transformers) do not go bad very often.
Oct 12, 2008 | Sunlight Supply 400 Watt Hps Sunsystem I...
Hid light output?
MH lamps are available in 175,200, 400 and 1000 watt sizes. HPS lamps come in 50, 75, 150, 400 and 1000 watt sizes. San Agro comes in 430w only, but it works with a 400w HPS ballast. Each lamp requires its own ballast, which comes with the fixtures that are designed to use these lamps, and are also available separately.
Aug 27, 2008 | Hydrofarm Agrosun Dayspot 60w Grow Light...
Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2 Logo
444 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
