Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic projection tv
Will not turn on standby light blinks 3 times (red light) is it worth fixing or should i junk it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Standby light blinking 3 times means a convergence error. The two convergence IC's need to be changed Panasonic part# C5AA00000203 (do not substitute with a generic STK#) This is about a $300-$400 repair.
Posted on Sep 23, 2007
SOURCE:
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
373 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
