Question about Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range
Replace thermostat Model # 362.72201891
I have to replace the thermostat on a Kenmore gas range. The model# is 362.72201891. Do you have instructions/schematic so I know how to get the old one out and install the new one? Can you give me those instructions? Do I need any special tools? So far, I have purchased the part. \ Thank you, Jeff Steiman
huuum
  • 750 Answers
SOURCE: kenmore range
You said, you have a 12 year old Kenmore Range. Smooth-top, over which only 3 eyes now work.
And you've lived with this for a couple of years. But now the bottom element burned out.
It sent sparks flying as it glowed brightly and released fire as this bright spot moved around from one side of the element to the other and finally went out.
You would like to replace whatever is needed.
Please help determine what is needed.
This is the old model # PLT083-2. You see it inside the door.
My advice is that after 12 years and a number of failures. especially the sparks!
You should replace this range! Do not put good money into bad!
I believe you deserve the pleasure and comfort of a new range before the holidays!
Here is a report I just read !
I believe it will help you decide and you may find it very interesting!
Repair or replace you appliances?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive appliance
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
I believe I may have solved your problem, with some Profesional sound advice!
If you have any questions feel free to ask!
Please remember to leave me a solved rating before you sign off!
Thank You, HUUUM
Posted on Oct 01, 2008
  • 323 Answers
SOURCE: Need to replace drop in range
All you have to do is make sure you have the same drop in top as the hole cut for it. Measure the opening, and then measeure flange to flange on the one you have. The flange will be 1/2" or so bigger than the hole; that's what holds it in.
They are ususall 30 or 36" wide. It doesn't have to be a Kenmore, just match the color to everything else.
Need to know how to disconnect it?
Dan
Posted on May 11, 2009
rylee_smith
  • 8619 Answers
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
jsrock516
  • 5911 Answers
SOURCE: How to replace the electronic oven control on my Kenmore range
If the Electronic Oven Control (EOC) requires replacement, the following link gives you step-by-step instructions on how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
This is not a difficult repair, but if you have questions, or require additional assistance, please post back and let me know. I hope this helps you.
Posted on Jan 10, 2010
SOURCE: Kenmore gas range model 790 door glass shattered, handle problem
We have suffered the same problem for the past 3 yrs. We first had the door all fall apart and I screwed it back together thinking that someone missed tightening a screw. Then shortly after the 1 yr warranty was up it happened again. Sears would not help, first told me that there was a recall, then not. After 6 departments and 12 people later they sent me on to whirl pool the manufacturer who said "see sears".
Anyways since we are abandoned by Sears who we trusted (as parents did) we are on our own, here is how I solved it.
After several times of the screw popping out and chipping and stripping the treads in the handle; I too switched out the bottom handle with the top but now at 3yrs old both handles had the threads stripped and chipped and the oven door fell apart during Thanksgiving dinner with the mother law 2009.
The next step for me after another round with Sears with no results (except they said it was common problem) and a letters to Att. Gen. (keep the letters flowing as they are hearing) was to go to the hardware store. I was able to find (not at the main hardware stores, had to go to mom/pa old fashion hardware store) a packet of #10 Sheet metal screws (Stainless steel) 2 1/2" long and a flat washer. This worked. Cost $1.18. Note it does strip the factory threads, so if your present threads are not too bad you may not want do it. You need the washer because the 2 1/2" is slightly too long. 2 1/4" would be a better length but I could not find them.
I would think Sears would want to avoid the bad press by sending all of us $1.18 worth of hardware out. Sears offered to sell me new handles, but I was not about to give them any more of my $.
And I agree it is a very stupid design to have to small handle (where the most stress is) holding the door/glass together.
Note if glass breaks, do not mess around, buy the proper part to go back in.
Posted on Jan 21, 2010
Broiler not working. How can I replace the fuses if that is the problem? Kenmore Range bought in 2002. Model C970-595081 Serial NF 2171 0264?
the model number you sent doesn't come up,is it gas or electric?if it's gas most likely it will be an ignitor.if it's electric probably the element.send correct model number off the machine,open the bottom draw,look at the left or right part of the frame and you'll see a tag with the model and serial numbers,just need the model
Mar 06, 2011 | Kenmore Kitchen Ranges
I have a kenmore gas range the oven seems to light the oven burner ever 10 sec and wont stay on model # 362.75497000
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 26, 2011 | Kenmore 71052 Gas Kitchen Range
Kenmore gas range model 790 oven won't light "glow plug igniter not coming on there is continuity through thermostat "valve"
Dec 18, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do I replace the oven ignitor on Kenmore model # 665 72173301?
The following link explains how to access and/or replace the igniter in a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Oct 15, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range Logo
147 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
